displaying posts 1 to 25 of 43
Author Subject: head gasket
JWP EFi
Turbo Legend!
where can i find a 1.6mm gasket?
Posted 15th Jul 2013 at 22:52
scoobydoo for an XU 16v engine, but you should never need one that thick.
Posted 15th Jul 2013 at 22:55
JWP EFi
Turbo Legend!
scoobydoo??
picking up head tomorrow, it has been skimmed flush to marker
Posted 15th Jul 2013 at 23:02
measure it first Thumbs up
scoobydoo = not a clue.
Posted 15th Jul 2013 at 23:22
JWP EFi
Turbo Legend!
assuming its skimmed flush, ie no marker left, what gasket can i get away with?
Posted 15th Jul 2013 at 23:24
no idea how deep the marker is, but 0.2mm +/- 0.05mm is max, from 137mm, hence peugeot selling you a 1.4mm gasket, and a std 1.2mm.
Posted 15th Jul 2013 at 23:44
We used a head saver once after having a head skimmed that was unknown ? I can try and find out some details ?
Attaches to the block under the head gasket ? Came with some sort of glue to permanently attach to the block Yes
Buggered if I can remember who we got it from but I can find out Thumbs up
Posted 15th Jul 2013 at 23:49
JWP EFi
Turbo Legend!
ive heard of that before. if it wasnt for this head recently having all new guides, valves and tapetts then i would just bin it and use one of my spares
Posted 16th Jul 2013 at 07:18
Can you not deck the block instead?
Posted 16th Jul 2013 at 09:46
you can, but that brings in the same issues.
Posted 16th Jul 2013 at 11:13
would another head, cheap maybe with known bent valves
rebuild this head with the good valve setup new stem seals and a seat regrind
much more time consuming but wont that be more stable?
Posted 16th Jul 2013 at 12:39
I doubt it will take any more time tbh.
Posted 16th Jul 2013 at 12:42
JWP EFi
Turbo Legend!
after a few hours searching and many phone calls to various suppliers/specialists i can only come up with this, i can easily get a Fibre gasket - 1.4, 1.45, 1.5. 1.55mm for the 8v turbo 406/xantia. Are those dimensions the fitted thickness?
Believe it or not no one in the uk stocks a 1.5/1.6mm MLS gasket, according to PEC, Cometic are no longer producing them, another company said they could get me one but there is a 16 week back log!!
Also apparantly i can use a standard MLS gasket with my head and NOT have valve to piston interferance although i was told the ECU can't/won't retard the ignition timing to compensate for the higher compression ratio. I thought the 6's brain would have been more than capable of dealing with this seeing as its self learning
Anyone care to give me a second opinion? If none of this safely doable then i will have to scrap my freshly skimmed head and build a spare one up
Posted 16th Jul 2013 at 21:15
yep, a fibre gasket will be fine, I've used a 1.35 and 1.45mm ones where the head had been skimmed right to its limit.
you need to measure your head accurately.
the ecu will pull the timing back, it does have a knock sensor.
depending on the cams you have, and just how much it has been skimmed, I would not advise using a std gasket without valve cutouts, do not believe the others that say they're fine, if it was fine, Peugeot would not bother making a thicker gasket.
Posted 16th Jul 2013 at 21:21
superchargedblack1997gti6
I'm sure Rich W can get them custom made mate?
Posted 16th Jul 2013 at 21:23
JWP EFi
Turbo Legend!
T16 uses fibre gasket so based on that fact - good enough for me
I was originally planning to fit my 270 regrinds but not much chance of that now
is the fibre gasket's thickness the final fitted, ie, compressed dimension?
JWP EFi
Turbo Legend!
I didn't think to contact Rich, but what iv'e learned today is that anything like this that needs to be 'custom made' isn't going to be a quick solution
Posted 16th Jul 2013 at 21:25
all gaskets are listed by their fitted dimensions.
Posted 16th Jul 2013 at 21:27
JWP EFi
Turbo Legend!
mei, i don't suppose you have any corteco/payen part numbers that i can give to ECP so they can order me one up?
i have 414351P 1.55mm corteco
BY320 1.45mm Payen
Don't know how accurate these are
Posted 16th Jul 2013 at 21:30
not offhand, there is an online ecat.
but have you measured your head yet?
Posted 16th Jul 2013 at 21:40
JWP EFi
Turbo Legend!
i tried corteco's cat but it says 'engine not found'. I didn't have time today to collect head from engineers but it was bloody close to the marker so safe to say its now flush, hopfully not past it.
Ive got a set of snap on digital verniers so once i pick it up i will measure it. I feel better now i know there are gaskets available in various thickness's
Posted 16th Jul 2013 at 21:46
JWP EFi
Turbo Legend!
Got my head back today, not as bad as i was expecting, managed to source a 1.45mm gasket via my mate at ECP, annoyingly it won't be here till friday
Posted 17th Jul 2013 at 20:24
so how tall is it now?
Posted 17th Jul 2013 at 20:30
JWP EFi
Turbo Legend!
according to engineers its 135.20 so with the 1.45mm gasket i will only be a tad over standard compression.
Head gasket was a lucky pick, i handed ECP a selection of part numbers and all they can find is 1.1mm MLS and a fibre 1.45
Posted 17th Jul 2013 at 20:41
135???
Shock
136.8 is the thinnest peugeot say !
Posted 17th Jul 2013 at 20:47
