displaying posts 1 to 25 of 43
| Author | Subject: head gasket |
JWP EFi
where can i find a 1.6mm gasket? |
scoobydoo for an XU 16v engine, but you should never need one that thick.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
scoobydoo??picking up head tomorrow, it has been skimmed flush to marker |
measure it first scoobydoo = not a clue. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
assuming its skimmed flush, ie no marker left, what gasket can i get away with? |
no idea how deep the marker is, but 0.2mm +/- 0.05mm is max, from 137mm, hence peugeot selling you a 1.4mm gasket, and a std 1.2mm.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
We used a head saver once after having a head skimmed that was unknown ? I can try and find out some details ? Attaches to the block under the head gasket ? Came with some sort of glue to permanently attach to the block Buggered if I can remember who we got it from but I can find out |
JWP EFi
ive heard of that before. if it wasnt for this head recently having all new guides, valves and tapetts then i would just bin it and use one of my spares |
stan_306gti6
Can you not deck the block instead?________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
you can, but that brings in the same issues.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
would another head, cheap maybe with known bent valvesrebuild this head with the good valve setup new stem seals and a seat regrind much more time consuming but wont that be more stable? ________________________________________ Proud Member of the ASTOR Owners Club |
I doubt it will take any more time tbh.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
after a few hours searching and many phone calls to various suppliers/specialists i can only come up with this, i can easily get a Fibre gasket - 1.4, 1.45, 1.5. 1.55mm for the 8v turbo 406/xantia. Are those dimensions the fitted thickness?Believe it or not no one in the uk stocks a 1.5/1.6mm MLS gasket, according to PEC, Cometic are no longer producing them, another company said they could get me one but there is a 16 week back log!! Also apparantly i can use a standard MLS gasket with my head and NOT have valve to piston interferance although i was told the ECU can't/won't retard the ignition timing to compensate for the higher compression ratio. I thought the 6's brain would have been more than capable of dealing with this seeing as its self learning Anyone care to give me a second opinion? If none of this safely doable then i will have to scrap my freshly skimmed head and build a spare one up |
yep, a fibre gasket will be fine, I've used a 1.35 and 1.45mm ones where the head had been skimmed right to its limit.you need to measure your head accurately. the ecu will pull the timing back, it does have a knock sensor. depending on the cams you have, and just how much it has been skimmed, I would not advise using a std gasket without valve cutouts, do not believe the others that say they're fine, if it was fine, Peugeot would not bother making a thicker gasket. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
superchargedblack1997gti6
I'm sure Rich W can get them custom made mate?________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
JWP EFi
T16 uses fibre gasket so based on that fact - good enough for meI was originally planning to fit my 270 regrinds but not much chance of that now is the fibre gasket's thickness the final fitted, ie, compressed dimension? |
JWP EFi
superchargedblack1997gti6 wrote: I'm sure Rich W can get them custom made mate? I didn't think to contact Rich, but what iv'e learned today is that anything like this that needs to be 'custom made' isn't going to be a quick solution |
all gaskets are listed by their fitted dimensions.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
mei, i don't suppose you have any corteco/payen part numbers that i can give to ECP so they can order me one up?i have 414351P 1.55mm corteco BY320 1.45mm Payen Don't know how accurate these are |
not offhand, there is an online ecat.but have you measured your head yet? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
i tried corteco's cat but it says 'engine not found'. I didn't have time today to collect head from engineers but it was bloody close to the marker so safe to say its now flush, hopfully not past it.Ive got a set of snap on digital verniers so once i pick it up i will measure it. I feel better now i know there are gaskets available in various thickness's |
JWP EFi
so how tall is it now?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
according to engineers its 135.20 so with the 1.45mm gasket i will only be a tad over standard compression. Head gasket was a lucky pick, i handed ECP a selection of part numbers and all they can find is 1.1mm MLS and a fibre 1.45 |
135???![]() 136.8 is the thinnest peugeot say ! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
