I'm so angry with myself
| Author | Subject: I have done the stupidest thing ever |
tony1991
Regular Location: northampton Registered: 07 Nov 2008 Posts: 406 Status: Offline |
So flat battery on the Rallye was fittin all interior back into day so I put this booster pack I have on the battery so I could open an the boot, an I did the stupidest this ever got the terminals wrong now the car won't star pump priming intermittent. Tried different ECU it was the same could it just be the relay I have also removed that battery now as it will be f**ked I'm so angry with myself |
rikky
doubt it's made any difference to the battery, have seen it done numerous times. probably fused something, doubt you've done any major damage. have seen moron coach drivers with booster packs putting them on coaches wrong and its usually ok________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
superchargedblack1997gti6
yes you should,be fine just check all you're fuses mate should get to the bottom of it!________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
tony1991
Il have to have a look in the week then I have spare relays do you think I could have blown that up |
It's because as you say - you put them on the wrong way round.Try again this time putting the red jaw on the positive terminal. ________________________________________ ![]() |
gilesy
Seasoned Pro Location: Greenwich - in that London Registered: 03 Apr 2006 Posts: 5,133 Status: Offline |
I thought this thread was about when Jimmyhackers superglued his pubes to his face to make himself a quick cheap beard for no cost |
Or a rallye stripe tattoo to the leg even.________________________________________ ![]() |
stan_306gti6
Yep, you'll have popped a fuse, nothing more.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
tony1991
Checked all fuses they seem to to be fine, changed the relay and it is the Same The relay is just clicking away at me Any ideas |
tony1991
Any ideas anyone ? I want to get it clean up an put up for sale but need it running |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
Have you individually checked the Relays to make sure none of them have burnt out? Checked the fuses within the engine bay? Has the fuel cut off switch enabled? (Red button top right of engine bay) - Press it and see whether that is the case. ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
tony1991
Are the green an orange things in fuse box under dash relays I checked all fuses and ones in the bay. Il check fuel cut off tomorrow Thanks |
rich306
Yes, they are relays ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
aaron6
Sounds like the batteries f**ked. Have you offered a meter over it? Mine was just clicking when it dropped to 10v. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
swiftyboi006
Charge the bat________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
tony1991
Found two burnt relays. Changed them fort I had sorted it pump was priming then went back to been intermittent, I have swapped the battery |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
gilesy wrote: I thought this thread was about when Jimmyhackers superglued his pubes to his face to make himself a quick cheap beard for no cost people who use scape goats need to ________________________________________ the world is changed by people in sheds |
jimmyhackers
check fuses, press that rubber fuel relay switch behind the ecu, check your battery,connecting the boooster pack may or shorted a cell or two in their meaning it wont ever be fixed by charging. it could still show the correct voltage but have minimal amperage. i may also suggest if you using a cheap battery charger you may be fooking/not fully charging your batteries. my garage charger will fill up my battery about 75 80 percent and say its full.. if i then put it on my smart charger i can pump another 8 amp hours into it. its like this for all my SLA batteries http://www.ebay.co.uk/itm/New-iMax-B6-Lipo-Li-Po-NiMh-Li-ion-LiFe-RC-Battery-Digital-LCD-Balance-Charger-/130954120354?pt=UK_ToysGames_RadioControlled_JN&hash=item1e7d794ca2 this is what i have, honestly one of the best thing ive bought in a while, its saved me a fair few batteries from the tip. and all my batteries are charged up fully and safely and for 15-20 quid its well worth it ________________________________________ the world is changed by people in sheds |
tony1991
Right I have tried all of the above and changed the battery an still no joy I have got the point where I have fell out with this car so thinks it going up for sake as a non runner |
don't do that, giving up is for losers.And I really want to know what's happened and what it takes to fix it! ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
