Author Subject: 106 gti running on 3
pebbles167
Pressure washed the engine last night, failed to start afterwards. Left it over night, car started fine, but is now mostly rubbing on 3 cylinders. Any common things I should be aware of?
Cheers,
Pebbles Thumbs up
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 11th Jul 2013 at 16:06
take coils & plugs out, water in them. my 406 v6 did it, left them out overnight & all ok. unless you've done terminal ECU damage but doubtful
Posted 11th Jul 2013 at 16:09
Buy a steam cleaner? Unsure
Posted 11th Jul 2013 at 16:11
pebbles167
Had the coilpack, plugs and map sensor out already.
2008 BMW K1200R
Posted 11th Jul 2013 at 16:13
try wd40'ing the coilpack plugs themselves and get some compressed air on everything to blow drips out. one single blob of water on something is all it takes
Posted 11th Jul 2013 at 16:16
pebbles167
And now its running on 4, ta guys Smile
2008 BMW K1200R
Posted 11th Jul 2013 at 16:28
pebbles167
Back to running on 3. Random with no explanation. Took all sensors, inlet, airbox, coilpack, plugs and just about everything else, tested all spark plugs, and each port of the coilpack. Despite electrocuting myself massively, nothing has helped. Been at this since 5 pm Sad
Furthermore, now every time I try and start it, its failing, and squirting fuel everywhere. Seems to be coming from under in inlet manifold, but can't confirm as I'm working alone and cannot see.
Please help Sad
Edit: can confirm its coming from below inlet, looks to be the fuel pressure regulator. metal pin clip isn't doing its job properly. Or I'm not fitting it correctly.
I've joined 106 owners, gonna see if they can help. Bloody pugs!
2008 BMW K1200R
Posted 12th Jul 2013 at 08:12
Are we now beginning to see why this was cheap for no explanation? Dunno
Posted 12th Jul 2013 at 08:49
fix the fuel leak...
Posted 12th Jul 2013 at 09:49
jimmy_boy
Fuel vapour and massive electrocutions under the bonnet?
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 12th Jul 2013 at 10:39
pebbles167
Fuel leak came after the electrocution LOL
The 3 cylinder issue was before this, each plug sparked, and each coil pack port was working. In neutral, the car is running on 3 up until around 4k when all 4 fire. In gear its present throughout the rev range seemingly.
2008 BMW K1200R
Posted 12th Jul 2013 at 15:55
pebbles167
106 gti now sold Laugh my ass off
2008 BMW K1200R
Posted 12th Jul 2013 at 15:56
I would have said check the wiring, its a common issue on 106 looms LOL
Posted 12th Jul 2013 at 15:58
pebbles167
I'll pass that on to the New owner Thumbs up
Hmm.. I'm without a car again.
I'm thinking 206 1.6 hdi or Clio 1.5 dci. Thoughts?
Cheers,
Pebbles Smile
2008 BMW K1200R
Posted 12th Jul 2013 at 16:04
Thoughts?
Cheers,
Pebbles Smile
Stop buying s**t cars thats my thoughts LOL
Posted 12th Jul 2013 at 16:05
hsustyle
I had this on one of mine, turned out to be an issue with injector loom plugs.
Beef Beyond Belief
Posted 12th Jul 2013 at 16:09
pebbles167
My thoughts were injector plugs, ran better when they wrte cleaned.
And rat, what woukd you suggest? LOL
2008 BMW K1200R
Posted 12th Jul 2013 at 16:11
craig-gti6
Get another 6Thumbs up
Posted 12th Jul 2013 at 16:14
Why the change from performance hatch to diesel s**tbox?
Posted 12th Jul 2013 at 16:15
pebbles167
Gonna save some moneys for the next year or so. Going from 25k a year to 15k with this new job has kind of messed me up a bit financially. Wink
2008 BMW K1200R
Posted 12th Jul 2013 at 16:32
Get a push bike Thumbs up
Posted 12th Jul 2013 at 16:39
If you want to save money and not doing alot of miles then either a ford focus 1.6 or 106 derv
Posted 12th Jul 2013 at 16:40
pebbles167
I do a fair amount of mileage, I love driving. As long as i can take me and my daughter to the seaside in relative comfort with a fair amount of briskness in a £1000 car, while saving fuel ill be happy.
Both the 206 and the clio have around 100bhp I've driven both and I like them.
And Adam, I had a push bike once, I f**king hated it Thumbs down
2008 BMW K1200R
Posted 12th Jul 2013 at 16:46
Id say a 306 hdi then or a xsara hdi 110 Yes
Posted 12th Jul 2013 at 16:51
pebbles167
Had a 306 hdi, didn't think much of it. Also it was noticeably noisier, slower and worse on fuel than both the aforementioned cars. Was a much better looker and handler though.
2008 BMW K1200R
Posted 12th Jul 2013 at 16:54
