Author Subject: Ok to remove heat exchanger wehn fitting oil cooler?
daipugralio
I'm half way thru a 205 gti6 engine conversion (for road rallying) and wondering if I can get rid of the heat exchanger and just fit a sandwich plate straight to the block?
I have a 13 row mocal oil cooler, pipes and all fittings here off my old rally car and I've got the sandwich plate arriving 2 moz.
BTW this is not D James but a mate of his who he's allowed to use his username to ask this.... Thumbs up
d james
Posted 10th Jul 2013 at 15:15
Yep.
  • Posted 10th Jul 2013 at 15:20
    midlife
    dangti6 wrote:
    Yep.
    Short but accurateLaugh my ass off
    Cool
    Team 330™Cool
    Team "no front end or engine"
    Posted 10th Jul 2013 at 15:23
    its actually better to retain it and fit a shorter Renault filter, better warmup times.
    Posted 10th Jul 2013 at 16:50
    clen666
    If you remove it you'll need part no. 1103.54 to allow you to bolt on the sandwich plate
    Team 'unintentional rat look'
    Posted 10th Jul 2013 at 17:22
    I've just literally done this on mine all I've done though is remove the Coolant pipes and bridge them together. Will be fitting it directly to the block when I get the correct centre bolt Though Wink. So far so good doesn't take long to warm up still and oil temps are 10 degrees lower. Gave it some s**t the other night and never saw past 100
    Posted 7th Aug 2013 at 10:28
    Is that deff the correct part number? I wanna remove the heat exchanger completely now as it has a minor weap of oil. Thought it was the rubber O ring behind it but still leaking. Want to bolt the mocal sandwich plate straight to the block which requires a male thread at both ends.
    Posted 7th Aug 2013 at 10:29
    clen666
    post #257
    Posted 7th Aug 2013 at 11:23
    Nice one. Presumably need something to screw it in with though same way as a stuf with like 2 m20 nuts wound together on the end?
    Posted 7th Aug 2013 at 13:31
    i'm sure the one i got for my 205 gti6 conversion was different from that
    Posted 7th Aug 2013 at 13:38
    I managed to screw mine in by hand to the required depth. Spot of loctite and job was a goodun.
  • Posted 7th Aug 2013 at 14:04
    That's what I'm thinking I'll have to do. It's a lot shorter than I'd have liked. Turned up from pug today about £6 plus vat
    Posted 9th Aug 2013 at 13:51
    Ray Finkle
    Quick question regarding one of the heat exchanger hoses.it is the lower one branching off the thermostat housing base section,it hooks into some pipe that disappears behind the engine firewall side wtf does this go???
    Laces out Dan
    Posted 21st Nov 2013 at 14:42
