Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress.
displaying posts 26 to 37 of 37
Pages (2): 1 [2]
| Author | Subject: Pugfest help |
I've found holding the revs slightly higher than idle aids bleeding, as the pump is moving the coolant round faster________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
Turn the heating on full whack, open the bleed valve on thermostat pipes until water comes out and replace nipple. Then move down to the thermostat housing, undo the Allen key bolt can't remember the size off the top of my head but its possibly 4mm, don't undo it all the way just enough to you can see the pin hole machined in to it, this is where the water will disperse. Once you see water tighten it and move on to the rad. Open the bleed valve which will be to your right and once water appears your done Job jobbed. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
I'm a Peugeot / Citroen mechanic feel free to pick my brains while we're there. Also would recommend thermostat replacement and by far the best way to bleed is to use the top Half of a bottle with suitably sized end that fits in the top of the rad nicely and fill that with coolant. This makes the water level in the top of there much higher than the heater matrix and the air will naturally make its way to the highest point in the system. Your best off filling with the bleed points all open without the engine running to begin with unroll they p**s out then close them, have a good few squeezes of the rad hoses and start it up with the bottle of water still in the top of the rad. Then as Matt says open the bleed points once running till no more air comes out. Ends up making a bit of a mess but never fails. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
atterz
Seasoned Pro Location: Stafford Registered: 18 Feb 2011 Posts: 1,134 Status: Offline |
I always pressure bleed mine by holding my hand on the expansion tank and blowing into the overflow whilst someone cracks off the bleed screws. Never struggled to do it that way.The fans could be an airlock as mentioned or the blue plug may be away and not reading correctly, had this on my DT before. Im not 100% on the idling issue. Have you tryed cleaning the ICV out? And do you keep the throttle cracked slightly with a little rubber cap on the throttle stop to avoid it stalling on quick throttle closing? ________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
As you guys seem to really know your stuff, I am going to bring a new thermostat and coolant to Pugfest, would you kind gents give me a hand? I will provide the beer for when we are done ![]() I would try it myself, but I dont want to try it tomorrow evening, not have it bled up right, and it properly overheat on the way to Pugfest. ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
mattgti6phase2
You not running AC anymore? ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
welshpug! wrote: try a new thermostat. i had Advice from Miles & you should listen to Meir..!!!! I had The exact same thing .!.....took thermostat out flushed total system through with hose pipe for 15mins or so ..until totally clear water came out of each Bleeder & Fitted a new Peugeot main Dealer bought thermostat & new seal .!!! The crap that came out !!!!!! Was running at 90 before going to 96 traffic & Now 80-82 & 90 traffic but cools down so quick now . Used 50/50 ((((6litres ish ))))of mixed antifreeze to top up & bleed by blowing trough overflow & opening each bleed nipple .... Amazing difference to cooling... The car was hunting when temp went up ....not now |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,865 Status: Offline |
who's Mel?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rikky
PikeyLocation: cheshire Registered: 28 Feb 2004 Posts: 26,800 Status: Offline |
welshpug aka melonhead________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Post #35
welshpug! wrote: who's Mel? Opps I'm blaming spell checker on IPad .... Stop it Rikky |
atterz
Post #36
Legend of Meir________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
atterz
Post #37
Pages (2): 1 [2]
