displaying posts 51 to 57 of 57
Pages (3): 1 2 [3]
Author Subject: MOT Failure :(
Post #51
yes but balljoint is diff size and unsure on camber etc
Posted 19th Jul 2013 at 13:41
ryangti6
Post #52
As rikky has said if you fit phase 3 hub you will also need to swap the ball joint as they are 18mm, other than that It's a straight swap.
Only other thing you can do is have the hole that I assume has ovalled drilled out and a sleeve fitted to take it back to the correct size
Ryan
Posted 19th Jul 2013 at 15:36
Post #53
or you could do away with the hub, and fit a new method of wheel rotation on there, involving a standard computer PSU and a wagon wheel with a 13mm hole drilled in it. as you won't be able to mount the calipers anymore, you can rig up a hairdryer to blow the wagon wheel into a melted mess, therefore reducing the wheel entirely and the speed of the car will reduce
Posted 19th Jul 2013 at 15:40
jimmyhackers
Post #54
thanks ryan for the responce. ill crack on with my works 2morrow
kinda thanks for yours aswell rikkey. wagon wheels are awesome but i believe there better used as food and not car parts.
Posted 20th Jul 2013 at 01:06
jimmyhackers
Post #55
after a week waiting for a sodding 35 mm socket. my car will once agin be off to the mot station tommorrow.
only took a whole day, 2 heavy rain showers, 4 rounded nuts and bolts to drill/cut out, one brake sensor wire to fix after it broke during, s**t loads of rust n gearbox oil (cv came out) on my drive....
but i now have one fully working gti and one xsi half in bits. yay
Posted 31st Jul 2013 at 00:42
3rd time lucky
Post #56
Failed mine today Sad
Tbf it was expected.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 31st Jul 2013 at 00:52
jimmyhackers
Post #57
I PASSED YAY!!!!!
Posted 31st Jul 2013 at 20:28
Pages (3): 1 2 [3]
