But for next time I'm wanting something right for the job.
What does anyone recommend as there is a lot of them.
Thanks
| Author | Subject: Oil filter removal tools |
306er
Senior User Location: Brize norton/ caterham F1 Registered: 28 Jul 2007 Posts: 888 Status: Offline |
Had the cars up on ramps today came to the Picasso and did the oil filter want to move... did it f**k! Screw driver out... Done.But for next time I'm wanting something right for the job. What does anyone recommend as there is a lot of them. Thanks ________________________________________ |
Search eBay "oil filter pliers" £3 job done for most cars with metal filters. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
I use one of these: http://www.ebay.co.uk/itm/3-LEG-2-WAY-OIL-FUEL-FILTER-WRENCH-63-102MM-DUAL-DRIVE-REMOVAL-TOOL-REMOVER-/310657439149?pt=UK_Hand_Tools_Equipment&hash=item4854a055ad ________________________________________ Goldie the track car. |
prism7guy wrote: Just ordered one One of those tools I keep meaning to buy everytime I struggle with a filter, then forget untill I'm struggling the next time ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
On the gti with air con, it can be a right arse to try and get the pliers on the filter and move the filter if some idiot has done it up tight with no oil on the seal.Im waiting for K and N to start doing oil filters for the 306. They have a nut welded to the end so you can just put a 13mm spanner on there and undo it. Nice and easy! |
stan_306gti6
I have one of these and it works great on most filters.The one on my '6' I change fairly regularly plus I always oil the seal, so just a pair of big pliers does the trick every time. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
I have one of those 3 leg tools as well. Brilliant but of kit. For pugs the purflux tool is great as well its just a giant ring that grabs on to the indents in the end of the filter. Strap type ones are also good. 6's with AC aren't that bad. Lexus is200 are the biggest pain for such a tiny filter! Always stupid tight and can't get tools in there. Particularly as you say if some twat hasn't oil'd the seal. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
if its a car I've serviced myself they always come off by hand ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
footah212
Senior User Location: Paisley Registered: 16 Sep 2010 Posts: 861 Status: Offline |
I have one of thesehttp://www.tooled-up.com/ShowImage.ashx?Type=3&File=SEAAK645.jpg&Man=SEAL&Size=460&source=affwin Works great. ________________________________________ Phase 2 Blaze GTi6PS3 - Black Ops 2 Engine crane for hire Renfrewshire |
Niall
welshpug! wrote: if its a car I've serviced myself they always come off by hand ![]() Yep same. Unfortunately, a lot of garages assume they should be tight which is bloody annoying when servicing peoples cars! |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
I used a small crowbar and lump hammer to smack the side of it downwards to start it off ![]() ________________________________________ Less than 24 hours to go! |
stan_306gti6
ian7675 wrote: I used a small crowbar and lump hammer to smack the side of it downwards to start it off ![]() ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
306er
Pliers are on order. ________________________________________ |
lewisdmz
Senior User Location: plymouth Registered: 25 Jul 2009 Posts: 504 Status: Offline |
I foolishly bought one of those chain wrench things, what a load of s**t they are. |
I've used my dad's chain one and provided there is a reasonable amount of room around the filter to get your hands in and set it up i didn't think it was too bad.________________________________________ Goldie the track car. |
smithers
Seasoned Pro Location: Glasgow Registered: 22 Nov 2004 Posts: 1,016 Status: Offline |
footah212 wrote: I have one of these http://www.tooled-up.com/ShowImage.ashx?Type=3&File=SEAAK645.jpg&Man=SEAL&Size=460&source=affwin Works great. Another vote for this one ________________________________________ 1997 Black GTi6smithers205 at hotmail.com |
