Author Subject: fans
maddriver9
The first fan on my 6 is not coming on, ive done a search and come up with a few things.
Fistly ive pulled the temp sensor off the thermostat and only the secondary fan came on, could this mean the briton is ok?
is it most likly to be the motor is bust? and is it possable to fix with out pulling the front end off?
178bhp 205gti6
¼ mile in 14.2
Posted 4th Jul 2013 at 20:06
darzmat
If it is a motor then the front end does have to come off
Could possibly be one of the green relays between the fans that sends power to the first fan.
I got annoyed with mine and just wired them to a switch
Posted 4th Jul 2013 at 20:46
Sounds like one of the fan motors is dodgy, will need swapping out for another. Yes
Posted 4th Jul 2013 at 22:08
maddriver9
wherer are the green relays located?
really dont want to take the front end off as every nut and bolt is seized and rusty like the whole cars been at the botttom of the sea for a few years.
178bhp 205gti6
¼ mile in 14.2
Posted 5th Jul 2013 at 09:22
Top of the cowling at the front. 2 greens and a black.
  • Posted 5th Jul 2013 at 09:39
    maddriver9
    Am I being thick but I can't see the relays?
    178bhp 205gti6
    ¼ mile in 14.2
    Posted 5th Jul 2013 at 17:32
    Under a black plastic cover?
    Posted 5th Jul 2013 at 17:42
    iplay
    Try spinning the fan around by hand - sometimes they get stuck.
    The connector block for the fans sometimes gets dry joints - connector block below the air intake pipe.
    Although money is on changing the fan or the bitron.
    Posted 5th Jul 2013 at 20:39
    maddriver9
    found and tested both green relays are working but the relay that was at the bottom of the three, when unpluged its very corroded (like the rest of the car) and seem like its melted a slight bit.
    i will clean it up and try it again in the morning.
    178bhp 205gti6
    ¼ mile in 14.2
    Posted 5th Jul 2013 at 20:57
