Author Subject: Severe pulling (steering)
darzmat
Got a doner car to help get my car back on the road.
It came with koni shocks and lowering springs, and koni adjustable rears on a lowere beam that has no camber.
So over the last couple days i fitted the suspension and rear beam. Fitted my rear brakes as they were new calipers, fitted all new copper brake pipes to rear. Bled them today, and also filled up my gpearbox oil as i a shaft fell out when i was changing the passengers hub/nuckle
So i took it for a blast down down the road and back earlier and its pulling to the right slightly under acceleration and when i lift off it pulls really badly to the left.
What could cause this? What have i done or forgotten about?
Thanks for any advice.
Posted 29th Jun 2013 at 22:07
darzmat
Sorry for spelling lol, using my mates ipad
Posted 29th Jun 2013 at 22:08
wishbone bushes or balljoint, either shot balljoint or wrong size.
Posted 29th Jun 2013 at 22:10
Beam isn't on straight.
Measure it to a specific place on the metal bodywork. It will be back on the right hand side I reckon, maybe only 3-5mm.
You can see where the bolt washers line up on the old paintwork. Just undo the beam slightly and twat it forward Thumbs up
Posted 29th Jun 2013 at 22:19
sam1
Also check all suspension related nuts and bolts are tight- wishbones etc, and that the strut is properly located on to the knuckle.
Posted 29th Jun 2013 at 22:44
darzmat
Never thought of the beam. Im 110% sure that everything is tight up front as i wanted it done right all nuts and bolts were cleaned and greased up and tightened up one by one.
Will have a look at the rear beam shortly. And hopefully its just that.
I dont think its wishbone bush replated as they were done not long before it went off the road.
But the ball joint bring a different size is a good shout
Thanks guys
Posted 29th Jun 2013 at 23:00
  • Posted 29th Jun 2013 at 23:22
    I pitta that...
    Posted 29th Jun 2013 at 23:58
    darzmat
    Uve lost me dan....
    Posted 30th Jun 2013 at 01:19
    beez_neez_gt
    I wouldnt touch that if you paid me, it's only cooking on the bottom section lol.
    I think Dans saying its Donnas fault lol.
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 30th Jun 2013 at 01:31
    darzmat
    The beam definately isnt sitting straight, and cant get much movement in it. Its about 5 mm out. If the elongated holes were front to back as opposed to side to side it would make my life so much easier
    Posted 30th Jun 2013 at 15:50
    darzmat
    Is there any other adjustments i can make?
    The car i took it off drove straight as i had it up and down the road a few times
    Posted 30th Jun 2013 at 15:51
    darzmat
    You were right lol.
    Sorted now just need tracking done.
    But the beam does sit slightly off....heyho
    Posted 30th Jun 2013 at 19:01
