Author Subject: MI 16 Rally Cams with Verniers
Hawkesfire
Hi
For sale Cat Cams rallycross camshafts Part No 4900528 with Kent verniers fitted off my rallycross, the car was at 252 bhp with throttle bodies, only removed due to installing a supercharged GTI6 motor in my rallycross car.
Specs
Lift 11.50 / 10.75
Duration 282/277
Can be used with hyd lifters
Looking for £300 and can send pictures if required located in N.E. but can post FOC to UK
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 26th Jun 2013 at 13:06
peugeot96
l guess you need deeper cuts in the pistons to use this cams?
Posted 26th Jun 2013 at 16:56
depends on lift at tdc, the RFY engine does have a lot of space but these cams are quite long duration so will need additional compression to work successfully.
Posted 26th Jun 2013 at 16:59
