| Author | Subject: adjustable bottom ball joints |
JWP EFi
Does anyone do the above? Looking to get B8's to replace my KW's but obviously won't be able to fit my adjustable top mounts, after playing about with different ammounts of camber i am keen to have some form of adjustability with the new setup |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
you'll need longer shafts if you push the balljoints out further.you could send some hubs to bridgecraft and they can alter the angle for you. Not sure if they do an adjustable variant as such though, the old Peugeot sport 205 group A hubs were as they had bored out hubs and an offset sleeve rather than just a straight bored sleeve, if you rotated it you could alter the angle. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
mei - i did consider the bridgecraft option but i would really like adjustability, in fact if i could work out my optimal camber setting i had on kw's then i suppose i could get them to machine my hubs to my spec |
What sort of adjustable top mounts have you got? Would be interested when you don't need them ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
JWP EFi
they are spoox ones, originally intended for the 205 gti |
stan_306gti6
Someone here was in the process of making a balljoint extension kit, can't remember who though. ![]() I'll see if I can find the thread. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
Buy some of PhilipM's tubular wishbones. |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
I know we've got a drawing for the touring car rose jointed BBJ setup which fits a standard arm, as mentioned though you'd need longer shafts really to be able to take advantage of them. You'd get away with a bit of adjustment but you'd have to check your driveshaft plunge carefully.What's stopping you fitting a b8 insert into a 205 bilstien coilovers body? That way you can keep your top mounts. Al ________________________________________ www.bridgecraftmotorsport.co.uk |
JWP EFi
i didnt know you could do that |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
I've got these.....![]() Guess I could be persuaded to part with them ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
allanallen
midlife wrote: I've got these..... ![]() Guess I could be persuaded to part with them ![]() They're not adjustable though?? ________________________________________ www.bridgecraftmotorsport.co.uk |
stan_306gti6
midlife wrote: I've got these..... ![]() Guess I could be persuaded to part with them ![]() That's what I was thinking of... ![]() Not adjustable no, but will increase the track as you seem to desire. On a side note, Wayne why don't you sell them? I've pointed it out before that they're not compatible with the 330mm Brembo kit. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
allanallen
As the title suggests the op is after adjustability not necessarily an increase in track.________________________________________ www.bridgecraftmotorsport.co.uk |
midlife
They aren't adjustable like you say but my idea was to elongate the holes to give adjustment, sus out how far they need to be moved to get the correct amount of camber then make up some bits to fit either side of the bolts in the slots to fix them solid.I need to mock this up to see of it clears the 330mm rotors, I know the roll centre adjustment blocks from Bridgecraft won't fit with 330's ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
JWP EFi
some interesting ideas there chaps, next thing is the driveshafts. how far can we go using the above methods before longer shafts are required?If only coilovers had a much softer setting, there would be none of this malarky |
Revalve them for softer springs, sorted.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
JWP EFi
phillip - Please tell me morewhat do i need to do? |
midlife
T99PUG wrote: phillip - Please tell me more what do i need to do? Look into my eyes, not around my eyes, look into my eyes, your under... ![]() Buy my ball joints for £115 delivered. Aaaaand your back in the room! ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
JWP EFi
throw in the required shafts followed by your paypal details and it's a deal...... |
midlife
JWP EFi
midlife wrote: ![]() ![]() worth a try serously though, whats the crack with shafts? theres nothing thats interchangeable so its going to have to be custom made items, i won't be going down this road. My latest thoughts are getting my coilovers revalved providing i can find someone to do it |
midlife
i believe 406 shafts are 10mm longer than 306 shafts, that would match up nicely with these ball joints as they are 10mm longer than std...![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
JWP EFi
how accurate is your info mate? if its as simple as fitting them straight on with your joints then i may take them. What about replacement bearings? can't see these lasting too long on our roads. Also if they are 10mm longer, what camber do they give? |
midlife
I'm sure Mei & Jean Luc will be along shortly to confirm![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
JWP EFi
mei's usually on the case quicker than this lol. |
