Author Subject: adjustable bottom ball joints
JWP EFi
Turbo Legend!
Does anyone do the above? Looking to get B8's to replace my KW's but obviously won't be able to fit my adjustable top mounts, after playing about with different ammounts of camber i am keen to have some form of adjustability with the new setup
Posted 24th Jun 2013 at 19:50
you'll need longer shafts if you push the balljoints out further.
you could send some hubs to bridgecraft and they can alter the angle for you.
Not sure if they do an adjustable variant as such though, the old Peugeot sport 205 group A hubs were as they had bored out hubs and an offset sleeve rather than just a straight bored sleeve, if you rotated it you could alter the angle.
Posted 24th Jun 2013 at 19:59
JWP EFi
Turbo Legend!
mei - i did consider the bridgecraft option but i would really like adjustability, in fact if i could work out my optimal camber setting i had on kw's then i suppose i could get them to machine my hubs to my spec
Posted 24th Jun 2013 at 20:04
What sort of adjustable top mounts have you got? Would be interested when you don't need them Thumbs up
Posted 24th Jun 2013 at 20:44
JWP EFi
Turbo Legend!
they are spoox ones, originally intended for the 205 gti
Posted 24th Jun 2013 at 20:48
Someone here was in the process of making a balljoint extension kit, can't remember who though. Doh
I'll see if I can find the thread.
Posted 25th Jun 2013 at 05:46
devere
Buy some of PhilipM's tubular wishbones.
Posted 25th Jun 2013 at 06:39
allanallen
I know we've got a drawing for the touring car rose jointed BBJ setup which fits a standard arm, as mentioned though you'd need longer shafts really to be able to take advantage of them. You'd get away with a bit of adjustment but you'd have to check your driveshaft plunge carefully.
What's stopping you fitting a b8 insert into a 205 bilstien coilovers body? That way you can keep your top mounts.
Al
Facebook
Posted 25th Jun 2013 at 07:15
JWP EFi
Turbo Legend!
i didnt know you could do that
Posted 25th Jun 2013 at 07:28
midlife
I've got these.....
Guess I could be persuaded to part with them
Cool
Team 330™Cool
Team "no front end or engine"
Posted 25th Jun 2013 at 07:39
allanallen
midlife wrote:
I've got these.....
Cool
They're not adjustable though??
Facebook
Posted 25th Jun 2013 at 07:52
midlife wrote:
I've got these.....
Cool
That's what I was thinking of...Yes
Not adjustable no, but will increase the track as you seem to desire. On a side note, Wayne why don't you sell them? I've pointed it out before that they're not compatible with the 330mm Brembo kit. No
Posted 25th Jun 2013 at 08:19
allanallen
As the title suggests the op is after adjustability not necessarily an increase in track.
Facebook
Posted 25th Jun 2013 at 08:39
midlife
They aren't adjustable like you say but my idea was to elongate the holes to give adjustment, sus out how far they need to be moved to get the correct amount of camber then make up some bits to fit either side of the bolts in the slots to fix them solid.
I need to mock this up to see of it clears the 330mm rotors, I know the roll centre adjustment blocks from Bridgecraft won't fit with 330's Sad
Cool
Team 330™Cool
Posted 25th Jun 2013 at 09:24
JWP EFi
Turbo Legend!
some interesting ideas there chaps, next thing is the driveshafts. how far can we go using the above methods before longer shafts are required?
If only coilovers had a much softer setting, there would be none of this malarky
Posted 25th Jun 2013 at 21:23
Revalve them for softer springs, sorted.
Posted 25th Jun 2013 at 21:30
JWP EFi
Turbo Legend!
phillip - Please tell me more
what do i need to do?
Posted 25th Jun 2013 at 21:35
midlife
Look into my eyes, not around my eyes, look into my eyes, your under...
Buy my ball joints for £115 delivered.
Aaaaand your back in the room!
Cool
Team 330™Cool
Posted 25th Jun 2013 at 22:42
JWP EFi
Turbo Legend!
throw in the required shafts followed by your paypal details and it's a deal......
Posted 25th Jun 2013 at 22:46
midlife
Laugh my ass off
Cool
Team 330™Cool
Posted 25th Jun 2013 at 22:50
JWP EFi
Turbo Legend!
midlife wrote:
Laugh my ass off
Cool
worth a try LOL
serously though, whats the crack with shafts? theres nothing thats interchangeable so its going to have to be custom made items, i won't be going down this road. My latest thoughts are getting my coilovers revalved providing i can find someone to do it
Posted 25th Jun 2013 at 22:57
midlife
i believe 406 shafts are 10mm longer than 306 shafts, that would match up nicely with these ball joints as they are 10mm longer than std...
Cool
Team 330™Cool
Posted 25th Jun 2013 at 23:05
JWP EFi
Turbo Legend!
how accurate is your info mate? if its as simple as fitting them straight on with your joints then i may take them.
What about replacement bearings? can't see these lasting too long on our roads.
Also if they are 10mm longer, what camber do they give?
Posted 25th Jun 2013 at 23:11
midlife
I'm sure Mei & Jean Luc will be along shortly to confirmGeek
Cool
Team 330™Cool
Posted 25th Jun 2013 at 23:13
JWP EFi
Turbo Legend!
mei's usually on the case quicker than this lol.
Posted 25th Jun 2013 at 23:17
