Where can you get a new plug or is there a way of repairing the current one?
Astor 6
| Author | Subject: Door to car plug |
Ed_van_dijk
Senior User Location: Halesworth Registered: 10 Jan 2007 Posts: 636 Status: Offline |
Im on the understanding that you can get a new plug, I have a broken wire right where it joins the plug which is my speaker wire. Where can you get a new plug or is there a way of repairing the current one? ________________________________________ Astor 6 |
Drivers side? I may have an inner door loom and plug knocking about actually which you could swap over if it was the same.________________________________________ ![]() |
Ed_van_dijk
no its a passenger side chap. if you did that would be brilliant ________________________________________ Astor 6 |
Ed_van_dijk
Also if anyone wants to make this in the electrical section for me? Engines and electrical are too close together lol ________________________________________ Astor 6 |
In that case I've a pass door which I can remove the lot from. 2000 ph3 so should be the same as yours ________________________________________ ![]() |
Ed_van_dijk
that would be fantastic, inbox me your pay pal details and how much you want________________________________________ Astor 6 |
Ed_van_dijk
its the car side of the plug not the door, if that makes sense ________________________________________ Astor 6 |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
most people just ditch that part with the car after being broken,..and i suspect that will be with the main wiring loom too?,.. may be a case of stripping back the car to get to it po it out remove the pin from the inside and re solider all guess work like! ________________________________________ Proud Member of the ASTOR Owners Club |
Ed_van_dijk
Yes it is with the main wiring loom but you could cut them back at the plug and lengthen them and put a new plug in________________________________________ Astor 6 |
Once again you are in luck as I have one of those too ![]() You'd best like soldering! I'll gather up what I have tonight and we'll work something out. ________________________________________ ![]() |
Ed_van_dijk
thanks pal, my girlfriend's dad likes soldering, the amount of time i have cut his grass its the least he could do lol let me know ![]() ________________________________________ Astor 6 |
gnrlee
now that's an understanding Prospective farther in law! ![]() while where in the subject of wires,.. I need some wire with plugs for the mirror cover tweeters that cam on some of the later 306's got any of those Dan? ________________________________________ Proud Member of the ASTOR Owners Club |
gnrlee wrote: I need some wire with plugs for the mirror cover tweeters that cam on some of the later 306's got any of those Dan? Unfortunately not Dave. The last Ph3 I did had the tweeter covers but the wires had been butchered at some point. ________________________________________ ![]() |
gnrlee
dangti6 wrote: gnrlee wrote: I need some wire with plugs for the mirror cover tweeters that cam on some of the later 306's got any of those Dan? Unfortunately not Dave. The last Ph3 I did had the tweeter covers but the wires had been butchered at some point. never mind I'll be doing some butchering of my own i just need those connectors for the tweeters themselves! ________________________________________ Proud Member of the ASTOR Owners Club |
Ed_van_dijk
I may have some at home Dave. Ill have a look when i remember!________________________________________ Astor 6 |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
make sure you count the wired pins on you car and make sure the plug/wires your buying has the same or more pins connectedas different models have used different looms for electic extras |
gnrlee
Ed_van_dijk wrote: I may have some at home Dave. Ill have a look when i remember! ________________________________________ Proud Member of the ASTOR Owners Club |
gnrlee
gnrlee wrote: Ed_van_dijk wrote: I may have some at home Dave. Ill have a look when i remember! cully wrote: make sure you count the wired pins on you car and make sure the plug/wires your buying has the same or more pins connected as different models have used different looms for electic extras ![]() but id presume that these would be a different colour? surly it would just be a case of matching the colour wires? but if not then painstakingly clipping the wire from one plug and soldering it to the same point on the plug to where the original wire was if you get me? just don't get it wrong or your windows will be going up and down to the beat of the music ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
Never go on colours when matching Peugeot wiring. Go on the numbers printed on them.As mine is a GTi6 loom it may well be the same, Ed is going to cross reference to be sure. ________________________________________ ![]() |
cully
as said dont rely on the wire colours you will find multiple wires of the same colourpeugeot used wire numbers i have a drawing on the plug pin numbers and wire numbers that may helps you its for a Hdi with all pins connected ![]() |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
I am in need of the above. I chopped in a new loom and got the major things working, but now I'm stuck with 9 wires 2 green 3 red 3 light brown and I can't remember the other. I don't know what they bloody do though! So in short I need to find which ones do the central locking, the electric mirror and the outside thermometer and I think that's it ![]() ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
stan_306gti6
Moved to Electrical. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
cully
these drawings are for a ph3 hdi but should be good Offside drivers door ![]() Near side door with Temp sensor |
