Author Subject: airbag resistor use
greenie
Just removed the passenger airbag and replaced it with an upper glove box. I know I need a 1.8 ohm resistor to fool the ecu but is as simple as just plugging it in where the airbag used to be plugged in ?
Sorry if its a dumb question but I hate electrics.
Thanks chaps
Posted 20th Jun 2013 at 13:59
Matt_rallye
Give cully a pm on here or on 306oc he knocks up little resister kits for a small price
Posted 20th Jun 2013 at 15:06
greenie
Oh ok, thanks
I actually have the fused resistor ready to go. I just need encouragement that you just plug it into the orange connector in place of the airbag !
Posted 20th Jun 2013 at 15:38
Matt_rallye
I believe that's the way you do it, cully also did a guide over on 306oc Smile
Posted 20th Jun 2013 at 16:55
greenie
Nice one, thanks
Posted 20th Jun 2013 at 17:06
This is the lad you want: http://www.306gti6.com/viewprofile.php?id=22585
  • Posted 20th Jun 2013 at 17:46
    Niall
    correct. Just bridge the two pins on the plug (with the car off obviously) and job done!
    greenie
    Ace all done.
    Cheers fellas.
    Posted 20th Jun 2013 at 17:57
    cully
    that would be me then !
    1.8ohm resistor plugged in were the bag once was should help
    use a fused resistor though it will protect the rest of the system by not overloading the electronics in the airbag ecu on detination ,the fuse will blow instead Wink
    1.8 works on PH3
    i measured bags at 2.7ohm on a ph2 but have used 1.8's on these systems too
    i have listings on ebay for
    1.8
    2.2
    2.7
    3.3
    search for ebay seller cu11y70 Wink
    Posted 20th Jun 2013 at 19:31
    Niall
    1.8 works on PH3
    1.8
    2.2
    2.7
    3.3
    But the airbag ecu is only single use. Once its detonated one bag, it needs replacing. Unless your thinking the return voltage will detonate another air bag?
    Posted 20th Jun 2013 at 19:37
    cully
    the idea for using a fused resistor is it acts like an airbag!
    if you just put a resistor link in its place it may take all the current designed for say 6 bags
    so only 1 or two bags might detinate insted of all the intended
    Posted 20th Jun 2013 at 19:42
    Niall
    Ahhh i see.
    Posted 20th Jun 2013 at 19:43
    greenie
    It is your good self that I just purchased some from on the bay then !
    Posted 21st Jun 2013 at 14:45
    cully
    yes i think so
    if you ordered yesterday they were posted first class today Wink
    Posted 21st Jun 2013 at 16:02
    beez_neez_gt
    Can u send us an ebay link please ?
    So do all of the air bags need one or can u just fit one to any with others still working ?
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 21st Jun 2013 at 18:41
    beez_neez_gt
    Pug fee`ver,
    Posted 21st Jun 2013 at 18:44
    cully
    you only use a resistor on the loom ends where you removed the bag/pretensioner from
    you dont need to fit to any other bag that you want to still work
    or search "airbag resistor" and look for the value resistance you need
    there are other sellers who sell them so the choice is yours who you buy from
    Posted 21st Jun 2013 at 19:07
    beez_neez_gt
    Ok thanks, iv never searched for a member before so not sure how to.
    I have a phase two 98 car but may have ph3 airbag for all I know, could have been changed.
    Pug fee`ver,
    Posted 21st Jun 2013 at 20:31
    cully
    if your having search problems
    http://www.ebay.co.uk/sch/cu11y70/m.html?
    Posted 21st Jun 2013 at 23:32
