Author Subject: P-bush problem URGENT HELP
Pug bazza
Hello guys, make a fook up was tighting the 13mm bolt on P- bush and it snapped, it also has the 16mm bolt to, would I be able to get away with just the 16mm on there, or do I need to fork out for new p- bush it just been fitted, cheers guys needs urgent help as car is jacked up
Posted 20th Jun 2013 at 11:39
Pug bazza
The bush seems tight, gave it a wiggle, whist still on jAck, hope I can get away with it
Posted 20th Jun 2013 at 11:44
Drill it out and tap it for an m10 bolt, there's enough clearance in the subframe for a 10mm to go through.
Then buy a torque wrench Wink
Posted 20th Jun 2013 at 11:48
midlife
If you want to lose control, crash & die in flames then sure you'll be fine.
Otherwise if you're lucky take it off & there may be a chance of getting what's left of the bolt out so you can fit a new one.
Good luckThumbs up
Cool
Team 330™Cool
Team "no front end or engine"
Posted 20th Jun 2013 at 11:51
Pug bazza
Half is in the p-bush and I got half of the nut snapped, arrrrr so annoying this is and I even f**ked my chassis as jack dropped
Posted 20th Jun 2013 at 12:03
what kind of jack were you using?
please done say the standard one that fits in the boot?
may as well just put you're car up on a block of cheese!
if you haven't buy a 2 ton jack from machine mart or even Argos for about £15!
Posted 20th Jun 2013 at 12:08
Pug bazza
Was using the one they have at tyre centres the 2 tonnes, and I took it down n slipped so vexed, so I'm goin to drill the old bolt out, replace new one, hope it goes well so far it's just been messed up fingers crossed I don't mess nothing else
Posted 20th Jun 2013 at 12:54
Remove the wishbone and as above there may be enough sticking out to grip to get the rest out, if not it shouldn't be hard to remove it.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Jun 2013 at 12:57
fordygti
Invest in axle stands, never work off a jack, bloody dangerous.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 20th Jun 2013 at 13:14
fletch
Track Head
Fiver says he's lying dead under 1200 kilos of 306 by tomorrow
Posted 20th Jun 2013 at 13:16
I never work without mine,.. I like my life!
I also push the spare/wheels just removed under the sides just in case!!!! Wink
there's a happy thought! LOL
Posted 20th Jun 2013 at 13:23
this has just reminded me of an afternoon many moons ago when my and Joker were both working on out cars
his was at a T-Angle to mine and i just caught out of the corner of my eye his falling forward off the jack
but just happened to be at the front of his and push it back just in time to save both our cars LOL
Posted 20th Jun 2013 at 13:26
I once had one fall off and the wheel arch hit me in the back of the neck as the car came down, stopping on the hub and forcing me down but I was ok luckily. Never risked it since
Posted 20th Jun 2013 at 13:48
Pug bazza
I really need to get axle stands, lucky I was out of under the car or I would been fooked,
Posted 20th Jun 2013 at 14:04
Pug bazza
Pillipm, thanks mate did what you said, and it broke inside do couldn't get it out drilled it, and fitted new bolt, thanks guys and I am gonna get some stand any one know a good place to get them
Posted 20th Jun 2013 at 14:07
woody.
Halfords normally do a kit including a 2 ton trolley jack, 2 axle stands, 2 wheel chocks and a trolley thing to lie on. I've got all that and can't knock it
Posted 20th Jun 2013 at 15:34
Pug bazza
Il pop down on weekend woody, it's my first car so much stress, it's been in accident b4, had the engine blow on it last year, so I said to myself only to replace what needs urgent attention other than that let's it carry on, mates n family moaning saying your mad spending cash, so realise need to just carry on investigate if something playing up, but not to be to paranoid about it, like today putting the tie rod end in and thought I tighten the bolts as se if they tite, but ended up snapping the p-bush bolt lol, I do love my pug but need to just nit be to paranoid, lol sorry if going on abit just needed to get it out the system lol
Posted 20th Jun 2013 at 17:42
midlife
"Drilled it"Dunno
Please say you tapped it out to a bigger thread & used a corresponding bolt.
Cool
Team 330™Cool
Posted 20th Jun 2013 at 18:00
