displaying posts 1 to 2 of 2
Author Subject: alloy aftermarket radiator
rallyeash
removed from my 205 track car, this is a 50mm diameter all alloy radiator which is originally for Renault 5 fitment but will fit anything with the correct pipework.
this radiator is ideal because its twice as thick as standard but half the width so i ran my oil cooler side by side and had great temperatures for oil and water if it was on track or on the road in traffic.
the outlets are 32mm and the top hose comes directly back towards the bulkhead and the lower pipe does what you can see above.
I had a slimline fan mounted to it so you can see the fins have been flattened slightly but still works fine.
collection from the wiltshire/Hampshire area ideally but can courier if required.
£70 collected
£85 delivered
fitted on my 205
309 3dr K20 Type R
Posted 18th Jun 2013 at 19:38
rallyeash
Sold
309 3dr K20 Type R
Posted 19th Jun 2013 at 11:47
