Author Subject: Phase 1 Oil pressure guage - HELP!
BigTallPaul
Hi guys, I'm a newbie having just joined after buying a track ready Phase 1 306GTi6.
I can't get the Oil Pressure guage to move more than a couple of millimeters from rest.
Turn on ignition it moves about 3mm. Starting the engine, revving it etc doesn't make it move any further.
I'm not sure what to check first, any ideas ?
All help appreciated.
Paul
Posted 17th Jun 2013 at 15:37
ian7675
Techno Viking
Does it go up when you turn it on and then drops down again?
Less than 24 hours to go!
Posted 17th Jun 2013 at 15:41
24seven
Have you tried replacing the sensor?
BigTallPaul
Yes, I think so. Can check tomorrow, why ?
Posted 17th Jun 2013 at 15:43
BigTallPaul
Not yet, do you think that will solve it ?
Paul
24seven
As likely as anything I'd imagine. If the gauge is going up and dropping down, it sounds like it's not getting the signal from the sensor when running to me.
Posted 17th Jun 2013 at 16:00
ian7675
Techno Viking
Sorry, I'm getting muddled up I think. I thought the oil pressure guage was also the engine temperature gauge and only showed you the pressure briefly on start up and then returned to the start to show you the engine warming up etc. it has been a while since I owned a 6.
Posted 17th Jun 2013 at 16:07
Ian - Phase 1's have oil pressure gauges, Phase 2 onwards had oil level and temperature gauges. Yes
Posted 17th Jun 2013 at 16:09
24seven
On a P1 there's a dedicated oil pressure gauge in the middle of the tacho.
ian7675
Techno Viking
Ah fair one Thumbs up
Stan - thank you!
Posted 17th Jun 2013 at 16:45
No worries mate. Smile
Posted 17th Jun 2013 at 16:48
Moved to Engines. Smile
Posted 17th Jun 2013 at 16:49
Pull the plug off and earth it to the block, if the gauge is working it will ping the needle to the top, if it works, then replace the sender, if it doesn't, then there's a wiring fault.
Don't forget to wait for it to finish checking the oil level once you turn the ignition on.
Posted 17th Jun 2013 at 18:07
24seven
It shows the oil level with just the ignition on? I thought it just went to about half way on the gauge randomly (not joking). On the dipstick my car is slightly overfilled but on the 2nd click that gauge only goes about half way up until the engine starts.
Posted 17th Jun 2013 at 18:19
BigTallPaul
Thanks! Thats really useful info. Will try that and report back.
Anyone know how much a new sender costs ?
Thanks again, Paul
Posted 17th Jun 2013 at 19:54
ryangti6
Yeah it should light up above the pressure notches and the needle will go up to indicate oil level on the bit that has illuminated.
Ryan
Posted 17th Jun 2013 at 20:45
You're looking around £20 or so for a new sender if that is the issue. Yes
Posted 17th Jun 2013 at 21:05
come on Stan you should know better than to randomly guess the price, they're on servicebox at £90 plus vat LOL
Also marked NFP so you might need to go hunting for stock somewhere at a dealer, ask a dealer to do a search on their systems, that's if you are bothered about using an used one, personally I woildnt be as they dont tend to fail very often in my experience.
Posted 17th Jun 2013 at 21:21
Shock
£90 plus VAT...that's ridiculous, it's only a little white round sensor!
If I was you, I'd prove that was the culprit and then have a hunt down at your local scrappy. Thumbs up
Posted 17th Jun 2013 at 22:21
trouble is they're only found on phase1 6's, s16's, and XSi's, and citroen equivalents, which are even rarer.
Posted 17th Jun 2013 at 22:30
24seven
I have a spare oil pressure sensor and adaptor that I bought to go on the VTS engine in my 309, but didn't get round to fitting before the thing was stolen. Is there a way I can test to see if it works while off the car?
Posted 17th Jun 2013 at 22:41
24seven
Is this the right one, minus the adapter? (Clickable thumbnail)
Posted 17th Jun 2013 at 22:47
BigTallPaul
Wow, Thanks all for the input. I have to say the responses I have received have been very helpful and quick. I will test the sender tomorrow if time allows and report back. As it happens I have already been offered a 2nd hand sender but wasn't sure if that was the problem. Thanks again, Paul
Posted 17th Jun 2013 at 22:48
multimeter and a pump Hmm
Posted 17th Jun 2013 at 22:49
