displaying posts 26 to 33 of 33
Pages (2): 1 [2]
Author Subject: SOLD - Supercharger set up
7057sam wrote:
armzs16 wrote:
Not fitting yourself then Sam? Was gonna say if you need any advice just shout. Welcome to the boosted club Big grin
Yeah, well me and carl chambers will do it.
Few question do I need 1 or 2 slimline fans? Push or pull? How did you mount yours?
Can I use a normal manifold gasket? Any tricky bits I should be aware of?
Cheers mate Smile
If you haven't done it before pugfest then you can go over mine with a fine tooth comb lol.
Tricky bits are getting the sunk in rusted up bolts out of the ancillary bracket bolted to the block, getting the order right of pulleys brackets and charger, bleeding /priming the charger circuit, and depending how its been mounted previously fitting the intercooler to the slam panel.
Mine is low boost cooler so different but the fans are held on with a kit of sort of cable tie things you push through the rad and clip on the other side.
Will dig out a few pics of the front end Wink
Looks a bit different now lol any excuse for a picwhoring Love
Posted 1st Jul 2013 at 21:43
7057sam
Cheers mate what mean by bleeding and priming the charger circuit
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 2nd Jul 2013 at 07:31
I made a thread on it somewhere there's instructions online. You have to prime the traction fluid from the reservoir up to the charger inlet before you can start the car. Otherwise the charger runs dry and can get damaged.
Posted 2nd Jul 2013 at 09:32
http://www.rotrex.com/Home/Technology/Product_Technical_Data.aspx
The thread I had about it appears to have been deleted Sad. But use the installation manual on the Rotrex site above. I cracked off the input union then got a mate to blow into a tube we stuffed into the top of the reservoir. Once fluid started p**sing out the union I tightened it up again. Simples!
I deliberately left the belt off the charger still so I could turn it over by hand a good few times then. You could feel it gettin easier to turn as fluid went round. Then put the belt on and disconnected the injectors and cranked the engine over for a minute or so to circulate properly then started. Check for leaks and once it's been running for a while the traction fluid cooler should be just about warm.
Posted 2nd Jul 2013 at 22:12
7057sam
Cheers pete sound like I need you down here helping us fit it Smile
Rallye dead Sad
Posted 2nd Jul 2013 at 11:11
If you were closer I'd give you a hand but I'm sure you'll manage without me Wink.
Posted 2nd Jul 2013 at 22:11
pete-gti
Where did you get them fuel lines from?
Posted 26th Jan 2014 at 01:01
pete-gti
Pages (2): 1 [2]
