Is there anything obvious that I'm missing??
Cheers,
Nick
AKA nick on 205gtidrivers.com
| Author | Subject: ABS light on... |
pooouk
Regular Location: Belper, Nr Derby Registered: 22 Jun 2009 Posts: 259 Status: Offline |
I changed the drivers side hub yesterday and now the ABS light won't go out!? The new hub has a different sensor (not new) in it and my ABS worked fine before. I cleaned the ring on the driveshaft with a wire brush and the tip of the sensor is perfectly clean. I have just been out the check the resistance as per the guide posted on here and that checks out (fluctuating between 1650 & 1400 ohms when the wheel is spun) and it gives identical readings to the sensor that came off the car in the other hub. I've not touched any other part of the ABS system, just the drivers side front that I have been working on. I've driven a good few miles in it as well, as I read that the system will reset once above 8mph.Is there anything obvious that I'm missing?? Cheers, Nick ________________________________________ AKA nick on 205gtidrivers.com |
pooouk
No one got any ideas????Nick ________________________________________ AKA nick on 205gtidrivers.com |
Rich E
Check the obvious things, if you haven't already, such as sensors plugged in, fuses, damaged cables, etc..If that's all okay then I'd swap back to your known good sensor, and if it's still not working with that refitted then that suggests the ABS ring has been disturbed in some way meaning it's not triggering the sensor correctly. ________________________________________ Rich |
Were you checking at the sensor plug or the abs unit plug?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pooouk
I have checked the sensor plug for resistance on both the old (known working) one and the new one. Both were coming up with identical values and were in the range that are given in the "ABS Checking" thread. I've not checked the abs unit yet, as I've not disturbed that, but worth a try. I'm leaning towards the abs ring being too corroded, I wire brushed it and have probably just taken too much rust off!!Would the light still come on if it was a blown fuse, or would it just not come on when the ignition was switched on?? Cheers, Nick ________________________________________ AKA nick on 205gtidrivers.com |
Rich E
Yes, the ABS light is on by default and the ABS unit has to switch it off if the system is healthy.Unplugging the ABS unit, for example, will bring the light on. ________________________________________ Rich |
I'd check form the abs unit plug, you've ascertained that the sensors are good, but not the rest of the ABS loom.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mechanical_repairs
As said above, check the resistances now at the main abs harness plug.Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
pooouk
I'll give it a go, but strange that all that I've done is change the hub and now it's gone from fully functioning to not!! Would rather not be spending another Saturday underneath it so will test the rest of it.Cheers, Nick ________________________________________ AKA nick on 205gtidrivers.com |
footah212
Senior User Location: Paisley Registered: 16 Sep 2010 Posts: 861 Status: Offline |
I've done all the resistence checks too and the ABS still doesn't work, never has.Take the bulb out . Feck the ABS!!! It has passed 3 mots since then too. ________________________________________ Phase 2 Blaze GTi6PS3 - Black Ops 2 Engine crane for hire Renfrewshire |
jamiek_uk2000
footah212 wrote: I've done all the resistence checks too and the ABS still doesn't work, never has. Take the bulb out . Feck the ABS!!! It has passed 3 mots since then too. I've done that on a Saxo before, with my 306 though I've just put a new driveshaft on and it has sorted it. The old ring had come clean off, so that may have been an issue ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
