Author Subject: Is this redundant?
chunder27
Guys
Another weekend, another spanner check on the now fully operational China.
Was doing some fumbling around today, trying to remember something stan told me about the reason why engine might be a bit stall prone and after disconnecting the light grey connector pictured, realised there was another one attached to the same loom!
http://www.flickr.com/photos/11026348@N03/8914008956/
Any ideas where it should go, is it even used?
Also found a totally loose bolt in the gear casing underneath!
And also tried to change the air filter, what a mission that is! I know let's put it behind the rear silencer perhaps, or I know on the windscreen! Very odd
Never mind, off to buy some much needed tools tomorrow!
Posted 1st Jun 2013 at 17:14
scotzman
Yep its a spare, I think its for a throttle body heater or something like that in colder climates.
Posted 1st Jun 2013 at 17:27
chunder27
Phew, I thought as much, was having a right old root around under there and couldn't find anything likely to be a mate!!
Posted 1st Jun 2013 at 17:35
Yep, as stated it's a spare on the loom, so don't worry.
Did you manage to clean the ICV Rob? Dunno
Posted 1st Jun 2013 at 18:57
chunder27
I couldn't get the bloody bolts out! Need a ring spanner! I know where it is though!
Going to buy some tools tomorrow, as its tough without them
Posted 1st Jun 2013 at 19:15
chunder27 wrote:
Going to buy some tools tomorrow, as its tough impossible without them
Yes
Posted 1st Jun 2013 at 22:14
chunder27
Managed to get it all done
As you said the sensor was black, not totally but the stem and the coned area, ad the whole inside was really sooty, so gave it a good clean and bizarrely car felt better after.
Idled a bit better when cold too.
Also managed to chage the air filter, no mean feat it seems!
A jack, brace and some some spanners helped
Posted 2nd Jun 2013 at 20:07
You can't go wrong with the halfords 150 piece set to get you started on the way to DIY tinkering.
  • Posted 2nd Jun 2013 at 20:18
    I told you it would run and idle better after a clean, they do get sooted up from time to time and then perform poorly. Yes
    Posted 2nd Jun 2013 at 20:19
