Author Subject: engine block/cylinder paint
7057sam
Hi guys
I'm painting my block and cylinder head tomorrow using this halford high temp paint
Just checking it will do the job it feels and sounds very watery and thin.
Any suggestions
Cherrs Sam
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 22nd May 2013 at 12:21
It will thicken up when it's stirred, the solvent has probably separated from the pigment that's all.
I used hammerite smooth on mine and others and it holds up well if suitably degreased first. Blocks don't actually get that super hot anyway so heat isn't a huge concern.
Posted 22nd May 2013 at 12:27
beez_neez_gt
Epoxy 2 part primer will do the job better, brush on once you have mixed the 2 parts using the correct ratio. Then once you have left it enough time to flash off you can apply some 2k black on top. Epoxy will if there is some slight rust on the block help stop it rusting anymore. Its perfect for aluminium blocks too, it wont peel of like many other block paints on aluminium.
Ask at your local paint-shop for car epoxy primer if you do want to use it.
Iv used the same stuff and it chips off too easily, wished id used epoxy primer but i didnt know about it back then.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 22nd May 2013 at 12:29
please don't do the head, it'll look crap.
as mentioned, a damn good stirring will help.
Posted 22nd May 2013 at 12:42
I did mine with halfords engine enamel black. The head - I just did the front and back around the ports to smarten it up a bit.
  • Posted 22nd May 2013 at 12:51
    don't see why the head will look crap, mine's been done red and i like it..
    Posted 22nd May 2013 at 12:52
    7057sam
    By head i mean just the bit the mani bolts on to like how dans done it.
    Rallye dead Sad
    Posted 22nd May 2013 at 12:54
    7057sam
    Love
    Rallye dead Sad
    Posted 22nd May 2013 at 12:55
    old pic too! it's very clean now and that's only cos i've had it apart anyway so cleaned it up as i've chucked it back together. box is nice and shiny, it'll be filthy though when i'm tearing my 205 gti6 through fields Hyper
    Posted 22nd May 2013 at 13:18
