I have narrowed it down to a multiplug above the pedals but there are loads there and I don't fancy stripping the lot.
***Breaking*** Ph3 Silver GTI 6 High Boost
| Author | Subject: lock and unlock wires |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
Does anyone know where I can find the lock and unlock wires for the central locking? Got 90 percent of my new alarm fitted but just can not get the locking working. I have narrowed it down to a multiplug above the pedals but there are loads there and I don't fancy stripping the lot. ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
bas_306gti
Regular Location: Eindhoven Registered: 06 Sep 2012 Posts: 108 Status: Offline |
central locking module is under the backseat, unlock/lock wires come from the door, so you can pick them up in the dash, the code on the wire is 6292/6293 (leftdoor) 6290/6291 (rightdoor). |
6waysforward
I can find 6293 and 6291 both locking wires in the same plug. Just can't find 6292or 6290 un lock wires. Any ideas? ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
bas_306gti wrote: central locking module is under the backseat, unlock/lock wires come from the door, so you can pick them up in the dash, the code on the wire is 6292/6293 (leftdoor) 6290/6291 (rightdoor). Not on a ph3. On a ph3, its part of the module under the dash underneath the hazard light switch. |
6waysforward
I found a unlock wire. Pin 4 of the yellow plug on the central locking ecu thats in the dash on a ph3.The car works on a negative pulse lock and unlock for anyone thats interested. Might do a ph3 central locking faq ![]() ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
