Author Subject: Changing PAS pump
braymond
Perhaps not the appropritate section, but can soneone advise how easy it is to change?
What will I need, aside from pump itself, any special tools and is it relatively straight forward?
Thanks
Rallye-R
Nurburgring article
Posted 21st May 2013 at 10:57
fordygti
Allen keys for the mount bolts and a screw driver for the pipe clips. That's all I think, obviously ull need to bleed it up with new fluid after.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 21st May 2013 at 11:00
I'm sure when I asked about mine someone suggested getting a ratchet spanner as access to some of the bolts is limited.
Bought the spanner, still haven't fitted the new pump over a year later so can't comment LOL
Also, replace the belt while you're there, just because.
Posted 21st May 2013 at 11:01
You will need allen key bits to use with a ratchet, as they are pretty tight and you have to undo them through holes in the pump pulleyThumbs up
Posted 21st May 2013 at 11:04
Pretty sure the clips are the single use type unless you have the special pliers. (which I do Smug)
Posted 21st May 2013 at 11:14
braymond
All good stuff. Thanks ladies
Rallye-R
Nurburgring article
Posted 21st May 2013 at 11:20
You can reuse the clips with some pliers and strong hands.
Clamp the hoses to prevent making a mess. Either a proper hose clamp or vise grips and a rag will do it.
A bolt to bung in the hose end isn't a bad idea. Subframe bolts are ideal if handy or a drinks bottle from your recycling bin.
  • Posted 21st May 2013 at 11:33
    Oh I know, but it tends to deform them a bit so they often don't clamp up as tight the second time around.
    Posted 21st May 2013 at 11:43
    fordygti
    Use jubilees, them clips are s**te.
    Posted 21st May 2013 at 11:53
