displaying posts 26 to 35 of 35
Pages (2): 1 [2]
Author Subject: high idle
fordygti
So your saying in some way or another it is icv fault?
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 22nd May 2013 at 21:35
Swapping out ICVs would not make an ounce of difference if the problem lies elsewhere.
It seems odd to me that by doing ONLY that, the problem seems to change.
Posted 22nd May 2013 at 21:39
fordygti
This is what I thought, but can't think what else to do. Could it be an ecu problem, it just seemed strange also that it was fine then when I turn the engine off and on again there is a fault.
I did think it could be a wiring problem but all bales has continuity from icv to ecu plug.
Posted 22nd May 2013 at 21:44
Ideally, you need to find out what those fault codes relate to that you found, that could be the answer there. Seeing as you've changed the ICV three times now though, I'd be more inclined to think it was a wiring fault related to the ICV as opposed to the unit itself.
Posted 22nd May 2013 at 21:48
fordygti
My friend who's an auto electrician is coming over Sunday so he can hopefully find something I can't.
Ill up date the thread if I find anything to help others in the future to this bloody annoying problem.
Thanks for the help stan. Thumbs up
Posted 22nd May 2013 at 21:50
fordygti
Problem solved, was a crap.connection were the icv are extended for the supercharger setup.
Silly problem. That's why it was fine.sometimes and not others.
Moral of the story, solder and heat shrink all connection not use crimps when you run out if solder.
Big face palm.
Thumbs up
Posted 24th May 2013 at 19:14
Big face palm.
Thumbs up
Excellent result. Thumbs up
I knew it had to be in that area, as the problem was varying when the only thing you were messing about with was the ICV.
Smile
Posted 24th May 2013 at 20:00
Crimps are fine, if done properly.
Posted 24th May 2013 at 20:23
fordygti
Wernt the best crimps, old ones.
Posted 24th May 2013 at 20:53
fatlapit
Post #35
Never solder a joint or a pin
Posted 21st Apr 2015 at 15:29
Pages (2): 1 [2]
