Author Subject: Cam Identification help required
rich6
Hi
I have a pair of non standard (i think) cams from my ph1 6 engine,
that met its maker in the last session at snetterton.... Pilot error
I am transferring them to my new engine and would like to know
how best to set them up timing wise.
inlet is 11.1mm of lift over base
exhaust is 11.1mm of lift over base
not sure on duration values
I will post pics of the cams and markings.
Cheers for any help
Rich H
Posted 18th May 2013 at 09:17
jeffers Forum Admin
rich6 wrote:
Hi
inlet is 11.4mm of lift over base
exhaust is 11.3mm of lift over base
Cheers for any help
Rich H
That seems a large lift! The cams should have their id stamped in the end like these below....
Not a very clear picture but you get what I'm saying.....Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 18th May 2013 at 09:26
rich6
I will double check, in the mean time do you know what the base diameter is for standard cams?
Posted 18th May 2013 at 09:43
jeffers Forum Admin
Not sure mate to be honest, try pm'ing welshpug it's the type of information he'll know! Thumbs up
Posted 18th May 2013 at 10:05
rich6
Cam markings attached...
a manufacturers logo and what I can make out to be "N"
Nothing on the end of the shaft
Anyone recognise these?
rich6 has attached the following image:
Posted 18th May 2013 at 12:50
rich6
You were correct about the lift, I make them to be 11.10 over base dia....
with my extra accurate verynear
Posted 18th May 2013 at 14:24
