displaying posts 26 to 50 of 50
Pages (2): 1 [2]
Author Subject: Rallycross 205 with GTI6 Motor
Hawkesfire
Just a little update
Well on my USA trip I had boring meetings so was looking on e bay and found a tidy 206 shell with a cage so after a few click it was mine
So the new plan is to drop all the running gear out of the 205 into the 206 and install the H/B supercharger into this so I have plenty of late nights over the next few weeks but it should be great fun to drive once completed.....
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 28th May 2013 at 23:43
Takedown
Great project!!!
Posted 29th May 2013 at 09:08
Hawkesfire
Just giving an update so the 205 shell has gone to Scotland to be a track car so funds are ready for a new body kit as i fitted the GTI 180 rear axle with solid mount kit and set it to the correct height apart from with the 7 1/2 rims fitted the wheels are touching the arches so looking to get the Pam Am body kit for it to gain the extra width at the front and rear..
Stripped the shell of all its wiring and heater internally and wow what a great pile of rubbish there was......
Dummy fitted the engine in last night with the 206 subframe and it just will not fit or line up correctly so after talking to a fellow racer he has used a 306 subframe in his and changed the mounting points so will be installing the engine on the gearbox and top mount then lining up the subframe so i can get the drive shafts as straight as possible when the weight is on the wheels as this should help the car stop destroying drive shafts off the start.... also think i am going to have to move the strut tops back to ensure i have castor on the struts.
Good thing with this is i can fit the 306 drive shafts and the gear linkage looks ok as well but should i keep the BE1 gearbox or go with the 6 speed box as i think the LSD will swap over to this box???
will post some pics when i get chance....
marty
Posted 9th Jul 2013 at 13:22
You need to use 206 shafts unless you go very wide wishbones
Posted 9th Jul 2013 at 13:28
Hawkesfire
Using the 306 subframe, wishbones so should be ok with the 306 shafts???Dunno
Posted 9th Jul 2013 at 13:38
Guess so LOL
But whats wrong with the 206 one?
Just thinking out loud here, but compare the 206 DW bellhousing to the git6 one.
I'd see if the dw8 and 10 stuff will bolt on at least the back and box, probably needs a custom top arm, OR, possibly a phase 2 xsara vts top arm.
Clever parts bin usage, sod bodging a 306 subframe on Wink
Posted 9th Jul 2013 at 13:48
Hawkesfire
Problem with the 206 subframe is its too high and has no room for the exhaust to exit from the rear as it has a hump in it for the front exit exhaust.
Also wanted to beef up the subframe as it has to handle a lot of power so should not be too much of a bad job to do
Posted 9th Jul 2013 at 13:58
ahh, get a DW or EW subframe.
Posted 9th Jul 2013 at 14:24
How about high boost charging the EW10 engine from the 206?
Posted 9th Jul 2013 at 14:31
Hawkesfire
Post #35
Hi WelshPug didnt know there was different subframes for this car so ordered a new GTI subframe as there looks to be more room on that thanks for the advice.
Chris i have the high boost GTI6 engine already that has cost me £1600 just for the bottom end so changing engines now is not an option.
Posted 9th Jul 2013 at 14:43
Post #36
damn, you have money to burn Laugh my ass off
I'd have been down the scrappy!
Posted 9th Jul 2013 at 15:03
beez_neez_gt
Post #37
Why a 206 though there about as good as a chocolate spanner Sad I was expecting a 205 project. With the title and all.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 10th Jul 2013 at 08:40
Hawkesfire
Post #38
Championship is televised so they are looking for newer cars on the grid, i knew it would be the last year for the 205 so decided to change to the 206 as its the closest that the parts i have will fit..
Sad moment to see my 205 shell disappear as i have been racing these for year now and loved the way they handled.
Posted 10th Jul 2013 at 09:02
Post #39
Ahh I see, no worries then.
There was a guy on here that used to run a low boost 306 in rallycross and did really well. He now uses a 206 for the same reason as you (306 is now too old).
206 here = http://www.306gti6.com/forum/showthread.php?id=151120
Posted 10th Jul 2013 at 09:07
Hawkesfire
Post #40
Hi Chris
Thats Stuart's 206 who i will be racing against and its a very quick car but i will be basing my build around his car....
Fitting the new subframe tonight and seeing if the engine fits???
Posted 10th Jul 2013 at 09:26
Post #41
306 is the closest for the 205 bits Doh
Posted 10th Jul 2013 at 09:50
Post #42
Same problem though Mei.
Not able to run a car older than 10 years old afaik Yes
Posted 10th Jul 2013 at 10:18
Post #43
damn, that's s**t, I'd be rallying elsewhere then LOL
Posted 10th Jul 2013 at 10:20
beez_neez_gt
Post #44
My thoughts too, most cars over the 306 age are all too lardy n dont handle as well either in this kind of price range anyways.
Pug fee`ver,
Posted 10th Jul 2013 at 19:57
Hawkesfire
Post #45
Hi Just thought i would give an update, as sat in Angola waiting for my flight home........
Car was built with all the bit as below and it all fits great with the extra room in the engine bay.
Hawkesfire has attached the following image:
Posted 13th Sep 2013 at 20:22
Hawkesfire
Post #46
Once i got the car running for some reason it dropped a valve 2 days before racing on tick over luckly it did not damage the bottom end so stuck on a used head and off to the dyno
Got 220 BHP out of it with out even trying so due to time left it at this as was aware of the used head and set rev limiter to 5k to try and protect the engine as i justed wanted some track time to set up the car.
Managed 2 laps and the headgasket went so pulled in and enjoyed the rest of the racing weekend with a few beers.
Posted 13th Sep 2013 at 20:29
Hawkesfire
Post #47
Gar set up
Posted 13th Sep 2013 at 20:35
Hawkesfire
Post #48
Race day for 2 laps and lots of beers
Currently got Rich building me a new head and have purchased a PTS tarmac box with a 5.3 cwp and one of Rich's lightened steel flywheels so let the rebuild start again next week ready for racing on the 29th.....
Posted 13th Sep 2013 at 20:37
Hawkesfire
Post #49
Well the head gasket issue has cost me a little more than expected as i thought i would check the bearings out on the engine just in case any damage was done...
All have been damaged and marked the crank so new crank and bearings will be getting fitted this weekend and then to rebuild the top end and fit my new gearbox once i sort out the diff issue.
Hopefully will get it running over the weekend and then can take it back to the rollers to get mapped and see what power we can get out of it ready for Croft in October!!!!
Posted 26th Sep 2013 at 16:07
Hawkesfire
Post #50
Cars running but its getting too hot so need a biger rad or even put it in the back!!!
Posted 5th Oct 2013 at 16:03
Pages (2): 1 [2]
