displaying posts 1 to 25 of 50
Author Subject: Rallycross 205 with GTI6 Motor
Hawkesfire
Hi
thought i would start a thread about my rallycross car for anyone interested or who has good advice.
The Car when i bought it..... it has been a rallycross car since the early 90's and won quite a few championships over the years as a stockhatch then supermodified.
Hawkesfire has attached the following image:
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 16th May 2013 at 11:16
Hawkesfire
As you can see from the pictures it had been neglected when i picked it up so on with a full rebuild
Posted 16th May 2013 at 11:20
Hawkesfire
New body kit
Hawkesfire
new paint work
Posted 16th May 2013 at 11:21
Hawkesfire
At this stage the car was the following spec
Full Race MI 16 engine with 252 BHP running on Lumintion 3 d ecu and MBE throttle bodies
BE 1 gear box with TranX diff
Full Billy's suspension all round with 1.9 discs on the front and drums on the rear.
All ready for test Day at Lydden
Posted 16th May 2013 at 11:24
Hawkesfire
Test day went great apart from bursting a rear brake hose so all new aeroquip hoses fitted to the car.
Posted 16th May 2013 at 11:26
Hawkesfire
First race day at Lydden
It rained and rained but had a good first heat then in second heat the engine let go big time.
Valve head snapped and smashed the head and block so engine was scrap
Posted 16th May 2013 at 11:29
Car looks great, thanks for putting some pictures up Smile
Bad news about the engine though Sad
Posted 16th May 2013 at 11:33
Hawkesfire
New engine sourced standard GTI6 motor with 70k on it .....No
Installed engine and found that the head gasket was blowing 2 days before race day so mad panic to rebuild the top end..
Got it ready in time so off to Mallory
Had a great day of racing even when running a standard engine and had some pannel damage when chasing the british champion and he decided to stop in front of me ......Dunno
Won the B final easily and got on the back of the A final grid
Made a good start and then the front ball joint snapped on the first corner so that was it for the day....
Posted 16th May 2013 at 11:35
Hawkesfire
Rebuilt the suspension and repaired the bodywork ready for Knockhill
Bought some GTI6 front disc and fitted them with race pads what a diffrence even just testing on our industrial estate.
Car tested on the saturday on the industrial estate stages and ran great so off up to Scotland for racing.
Got up early Sunday and started the car Shock it would only run on 2 cylinders so new plugs , new coil pack , new leads and checked all the wiring but still no diffrent so did practice on 2 cylinders so i would quailfy to race
Checked every thing again tried more new parts checked fueling but no good so packed up and watched the racingSad
Posted 16th May 2013 at 11:40
Hawkesfire
Current plan is
Fit a Rotrex super charger and steel bottom end running throttle bodies and fabricated air chamber connected to a huge intercooler, new Omex 600 ecu and new wiring loom to be installed.
To make way for the supercharger and intercooler the radiator is getting moved to the back.
Lots of work and dosh so next race will be Lydden in August and i am looking for 350 Bhp + from this conversion...
Spoke to Rich at Lynx and he has been very helpful with advise so thanks bud.
Cars ready to start mocking up the supercharger and intercooler then once completed i will rip out everything and fit the new steel bottom end.
Posted 16th May 2013 at 11:47
Good work Smile
Look forward to seeing how you get on with ITB's and a supercharger Big grin
Posted 16th May 2013 at 12:01
fordygti
Yh, I look forward to seeing this to. Was thinking about it before, but I couldn't see the gains would be worth the money adding the bodies to a charged engine.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 17th May 2013 at 10:12
There won't be gains, but he's got them already so why not use them?
Posted 17th May 2013 at 10:22
fordygti
I meant for me and my budget at the time. I'm all game for seeing this done. Like say say he has them so mite aswell use them.
Posted 17th May 2013 at 10:28
May not be power gains, but surely still get some better throttle response, and could custom map it better surely having ITB's?
(Waits for Jim to come along and prove me wrong again Laugh)
Posted 17th May 2013 at 10:29
fordygti
Only pain in the arse bit would be getting everything to line up, ie. Custom inlet plenum with the charger and aux setup.
Would be good to see.though, never seen it done myself. Sure it has been though.
Posted 17th May 2013 at 10:35
playboyb
Great lil project you got there fell, bet that is great fun to drive in! Looking forward to seeing how the itb's go with the charger Thumbs up
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 17th May 2013 at 10:52
Hawkesfire
Hi
Thanks for all the comments, my thinking around using the itb's is that if i fit a dump valve then the charge pressure in the air chamber will stay high so when i open the throttles it will have boost pressure built up so instant power as looking at some of the vid's of the Lynx set up the hoses are sucked in so it must be vacuum in there due to the throttle body being closed so there must be a transition pause when opened.
I also want to go with Omex unit and Rich advised to try this so i will not argue with him .....
Will be interesting to see how it works with launch control and full throttle gear changes
Posted 17th May 2013 at 11:03
Hawkesfire
Oh look what has just turned up Big grin
Shiny Supercharger let the build begin Shock
Posted 17th May 2013 at 11:10
Eddleston
ooo this is a good thread! Thumbs up
Posted 17th May 2013 at 12:00
rallye1999
If you need a cheap engine/box ancilleries (sp) im only in redcar and cant be bothered with ebay Smile
Posted 17th May 2013 at 12:56
Hawkesfire
Hi
Thanks for the offer for the engine /box but i have a new bottom end with steel rods and forged pistons and i have a spare head that i am getting built up so should have everything i need.
Just reading my manual for the omex and it says it has the provision for a Knock sensor, i heard that the GTI6 standard engines have these fitted is that true and if so where is it or what is it as i think it might be tempted to fit one
Sad
Posted 17th May 2013 at 14:38
Yeah the standard engine has a knock sensor, it should be somewhere on the front of the block above the oil filter roughly between cylinders 2 and 3. It's like a black round sensor with a lead running from it and a bolt through the middle from memory. Smile
Nice project, I'm wanting to do similar with ITB's and a 'charger but keep spending money elsewhere on the car. Doh
EDIT: Circled the knock sensor for you. Smile
Posted 17th May 2013 at 14:49
allanallen
Hawkesfire wrote:
Hi
I think you're confusing yourself re. the dump valve. It will mean there's no pressure in the plenum rather than built up pressure, that's the point of it.
The pipes being sucked in on the videos will be due to the throttle body being fitted before the charger, yours will obviously be after. If you don't fit a dumpvalve your theory will sort of be correct, although the charger, throttle body plates and pipe work won't appreciate being battered by ever increasing boost when you let your foot off the throttle.
Facebook
Posted 17th May 2013 at 19:24
