Author Subject: Low boost rev limit
marco gti6
When does the rev limiter cut in on your low boost 6 or rallye??
Posted 10th May 2013 at 09:30
birk
There's a few different limits. Mine used to be 7450iirc
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 10th May 2013 at 09:33
marco gti6
Is it possible thet the rev dial shows more than the actual revs? Like 8000 rpm? Dunno
Posted 10th May 2013 at 09:34
yep.
Posted 10th May 2013 at 09:46
superchargedblack1997gti6
8000 rpm That does seem excessive would of thought 7600rpm would be max you would see the needle go to.
Posted 10th May 2013 at 09:52
Also think about where your peak power is Thumbs up
  • Posted 10th May 2013 at 14:32
    peak power is the moment you hit the redline and it bounces back and forth
    Posted 10th May 2013 at 14:35
    I think the limiter on mine is 7800. I took it there once on the way back from mapping to see if it sounded like the world was about to end. I do like making the pretty shift light illuminate. Very sensual mood lighting that.
  • Posted 10th May 2013 at 14:38
    The limiter on the chip i have is 7800
    Tbh i think i'll be getting it changed to 7500 or something as 7800 sounds high to me?
    Posted 10th May 2013 at 14:57
    it is, especially for the standard hydraulic tappets, dunno where the low boost makes peak but a standard engine its at 6500, so there's absolutely no point whatsoever taking it to 7800, as there's sod all torque up there and no power for sure.
    shift at peak back onto torque, BOOM, job jobbed.
    Posted 10th May 2013 at 15:20
    Dumb question.
    Is it faster to shift at peak on a std car or just after
    Or neither and red line it everywhere?
    Posted 10th May 2013 at 16:22
    ryangti6
    I'd say about 6800-7000 on average, every 6 I've ever driven has felt slightly different to be honest though so it varies car to car.
    Ryan
    Posted 10th May 2013 at 16:33
    Yeah i'd say i change about there,
    Its what i think "feels" fastest but i wondered if there was a scientfic fact way of doing it
    Posted 10th May 2013 at 16:50
    You'd be better off getting into the next gear and powerband.
  • Posted 10th May 2013 at 17:04
    ryangti6
    It's what I go on mate, you can feel when you get it right.
    Ryan
    Posted 10th May 2013 at 17:22
    My low boost was originally set at 7450rpm. Yes
    Posted 10th May 2013 at 18:09
    Takedown
    7400 would be the max id be doing....
    Posted 10th May 2013 at 22:00
