Author Subject: Drivers Crystal Fog, Battery Box Air Feed, Gearbox Arch Liner +
matthew_eames
I'm after the following parts to get this thing back on the road....
O/S (drivers) fog lamp w/ clear lens & intact mountings
Inner arch liners (geabox cover on N/S & the same piece on the other side)
Battery box air feed (runs from fan cowling)
Aux belt top cover (P2 item)
Bulkhead heatshield lower mounting bolts (mine seems to be held by the top 2 only, and rattles a lot)
O/S side skirt rubber seal (may be steel reinforced, so perhaps not one to post)
P3 Stereo w/ code and surround
Drivers foam door seals - Intact
Un-bent wheel wrench (do they exist?)
Square tray from rear of central console - no broken lugs
Shipping required unless reasonably close to either Chester or Skipton areas.
I have a bag full of undertray bolts / fixings and new hockey stick clips (only wanted a few, got lots) which I could trade against some small items if you wanted.
Thanks
Posted 9th May 2013 at 22:04
matt_gti
Got the battery box air feed, aux belt top cover and the square tray from the rear of the centre console. £17 posted.
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
E39 535i - Daily driver
*Newest edition* E60 M5 5l v10 - The weekend car Smile
Posted 10th May 2013 at 00:50
matthew_eames
Done - Can you PM me payment details and I will send the monies over.
Posted 10th May 2013 at 12:22
matt_gti
You have mail....
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
Posted 10th May 2013 at 15:50
matthew_eames
Still looking for a number of these items, in particular the P3 Drivers Fog, Gearbox arch liner and a P3 CD Headunit with surround & code.
Plus everything above on the list, including a battery air feed pipe and possibly a rear wiper motor as I think the park location control on mine has gone.
Sourced the Aux cover from Matt_gti
Posted 18th May 2013 at 20:09
jord294
pretty sure i have a door seal.
i have a box of 306 stuff here. you're welcome to make me an offer on contents
Posted 18th May 2013 at 21:17
matthew_eames
Hi Jord
Could I come and take a look at what you have, would be good to have a chat sometime.
Posted 18th May 2013 at 21:58
jord294
Yes mate. I'm about tomorrow if you wanna pop up
Posted 18th May 2013 at 22:04
matthew_eames
Up bright and early to go mountain biking tomorrow i'm afraid, how about one evening this week perhaps?
Posted 18th May 2013 at 23:56
jord294
Tomorrow or Tuesday then?
Posted 19th May 2013 at 08:18
matthew_eames
Tuesday would work if good for you, PM me your address and I will head over after work
Posted 19th May 2013 at 12:57
matthew_eames
Still looking for a lot of this if anyone can help?
Also perhaps an entire P3 China Blue bumper if in good condition as the one on the car is a little worse for wear (would also take a drivers door handle as mine has clearly snapped and been replaced by a repainted one)
Posted 21st May 2013 at 23:46
