When the car crashed (in january, has been run without issue since several times including hard driving as previously mentioned) there was a puddle under it but I assumed it was washer fluid as this also spilled everywhere.
From reading around, it would seem that if your heat exchanger goes, the coolant can get oil in it. However, this begs the question, where has all of the coolant gone?
I will try taking the car to halfords, pouring coolant in and watching to see whether it is coming back out and onto the pavement or not.
Does anybody have any other suggestions as to what may be wrong, how I might go about checking to see whether or not the heat exchanger is faulty, and where the heat exchanger actually is (I know, newbie question). I'd appreciate some input please as this car needs to make it to Germany in a couple of weeks and it sure won't be doing it aircooled.
I'm about to go and have another visual check for leaks anywhere around the radiator/front of the car.
Thanks in advance!
RetroPug
or when was the last time it was checked?
