Author Subject: New water Temp sensor and gauge
dendle89
Basically i want to wiring in a new water temp sensor and gauge, are there any kits out there ? i have looked but i cant find any ?
Team 6 Cylinders
Posted 1st May 2013 at 13:42
thousands on ebay Unsure LOL
Posted 1st May 2013 at 13:45
dendle89
fancy sending a link mate ? (the ones i found dont do both its either one or the other)
Team 6 Cylinders
Posted 1st May 2013 at 13:47
are you not using the standard one on the dash? or are you after something as a secondary one, eg more precise?
Posted 1st May 2013 at 13:53
dendle89
secondary one
Team 6 Cylinders
Posted 1st May 2013 at 13:54
why?
Posted 1st May 2013 at 19:06
£2.80 for a digital fish tank one with probe LOL
  • Posted 1st May 2013 at 19:36
    dendle89
    Haha sorted ! In all seriousness anybody have any tips?
    Team 6 Cylinders
    Posted 1st May 2013 at 22:05
    As i said, why? Standard works fine.
    Posted 1st May 2013 at 22:28
    ryangti6
    Use the one fitted in the car lol.
    If you just want a separate gauge I'm sure I've seen some you can just run to the standard temp sender otherwise as rikky said on Ebay etc there are loads of gauges and they come with everything you need to make it work.
    Ryan
    Posted 1st May 2013 at 22:39
    dendle89
    The reading isnt accurate, ive changed sensor, dials etc but with no luck, so in going to plumb my own gauge in, atleast i know it will be accurate
    Team 6 Cylinders
    Posted 2nd May 2013 at 11:36
    It is accurate as these gauges are quite rare these days in that they are "live" gauges. Yes
    There must be an issue with your vehicle if you're finding it inaccurate.
    Posted 2nd May 2013 at 11:43
    ryangti6
    What Stan said mate, I've had loads of 306's and I've never had one that doesn't appear to be accurate.
    In what way do you think yours isn't?
    Ryan
    Posted 2nd May 2013 at 11:48
    what sender have you used?
    needs to be the 306 one to match the clocks, xsi is different iirc to a gti6, and different again to the v6.
    Posted 2nd May 2013 at 13:59
    dendle89
    Im not 100% sure think its the 406 one
    Team 6 Cylinders
    Posted 3rd May 2013 at 07:12
    If it's the 406 one then it probably won't be accurate. It needs to be correct sender for the car as Mei says. Yes
    Posted 3rd May 2013 at 12:00
    If after using the 306 one you still have issues I would look at the plumbing, might be its not right and you getting hotspots. I had this issue...
    Posted 3rd May 2013 at 12:33
    dendle89
    Yea, def think im getting hotspots ! anyway its all ordered, only thing is im going to have to put in on a switch as i dont want to fiddle too much with the electrics
    Team 6 Cylinders
    Posted 3rd May 2013 at 19:39
