Author Subject: possibly a epic fail?
Niall
So i bought some second hand B8s a few months back and fitted them. When i fitted them, i put bump stops on them and i thought it looked like there was very little travel. It also barely dropped at all. I have since found out that B8s have a internal bump stop. Correct? If so, ill definately be removing the ones i fitted at the weekend seeing as i am literally riding on the bumpstops LOL
Posted 29th Apr 2013 at 22:57
Takedown
Lol, if im correct they do have internal bumpstops...
Guess thats why it aint lowering mate Wink
Posted 30th Apr 2013 at 07:33
jamiek_uk2000
That must be the worlds stiffest suspension now then, just riding on a bumpstop?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 30th Apr 2013 at 07:52
Rich E Forum Admin
They do have internal hydraulic bump stops to prevent damage from over-compression of the rod, but that won't prevent the spring bottoming out so an external bump stop is still required.
As for the lowering issue, what springs are you using?
Nah, the foam bump stops on the front are surprisingly soft when you put a few hundred kilos on them.
Posted 30th Apr 2013 at 08:02
jamiek_uk2000
So do you need a shorter one then for the uprated shocks? I so where and what? I'm just waiting for some B8's to be ordered on payday so might aswell get the gear to go with it!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 30th Apr 2013 at 08:16
Niall
B8s with 30mm eibachs on. Tbh I'm not fussed if its low. That's never really been something that's bothered me. Just want it to be right that's all! Might just chop the bump stop in half
Oh and you would be surprised. It's not that stiff but it goes round corners like its on rails at the moment lol.
Posted 30th Apr 2013 at 09:17
matt evans
I used the OE bump stop with 25mm cut off it when i fitted B8's and 30mm eibachs on my 306. It never bottomed out or was mega stiff, handled the big compressions at high speed on the ring just fine
honestly3k wrote:
owain wrote:
Posted 30th Apr 2013 at 09:23
Niall
Cool ill do that then. Even when th shock is unloaded when the car is jacked up, there's probably 30mm shaft between the shock body and the bump stop and I'm sure most of that is taken up when the car is put back on the ground. Anyone got any pics of their car on eibachs and b8s just so I can see roughly how low it should sit.
Posted 30th Apr 2013 at 09:26
matt evans
Close up of mine on 16" wheels
One a bit further away...
Posted 30th Apr 2013 at 12:59
Ive bought 206gti bumpstops for my struts as they are 79mm which is 2cm shorter i believe.
Correctme if im wrong
Posted 30th Apr 2013 at 15:49
jamiek_uk2000
I've seen the Powerflex universal bump stop kit, with the dust covers included. I know that it's Powerflex, but surely a bump stop can't be bad
Clicky
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 30th Apr 2013 at 15:56
