Author Subject: Cheap Genuine ICV's
honestly3k
Hi folks,
Thought I would share my good fortune, rang ECP the other day to find out if part no. 436730100 was infact Magneti Marelli manufactured. Turns out it is so if you log onto carparts4less.co.uk (who are basically eurocarparts)....you can pick your ICV up for £67.20, and then by using discount code CP5LESS you can pick it up for a fiver cheaper still at £62.20 delivered. Thumbs up
Carparts4less.co.uk are cheaper listed than on the ECP website where same part is £93.60.
Carparts4less are basically DELIVERY ONLY. But I had to pick mine up from the local Yodel depot in Borehamwood.
My only gripe is it is supposed to come with a new O-ring seal which it didn't, plus I got a random screw which is pretty useless afaik LOL
My car has idled terribly for about the last 40K, stalling at junctions, dipping the clutch and after free revving so thought this price was too good to pass up considering the last time I checked at Peugeot a year ago for one of these it was £145 + VAT!!!
Guna go fit it now and pray that this cures my issues......
Hope this helps those of you that need new ICV's too
Posted 25th Apr 2013 at 15:26
NIce work Smile
Will bear that in mind Smile
Posted 25th Apr 2013 at 16:03
beez_neez_gt
Good work Thumbs up
Pity this didnt come up a few months ago LOL
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 25th Apr 2013 at 16:23
mik
Great tip - and it all works on the site too.
I'm just going to get one anyway as it will be 12 years and 100K miles younger than the one that is in there!
Cherry Rallye SOLD
Posted 25th Apr 2013 at 17:23
RetroPug
That's a long time to ignore such an issue!
Being clean makes a huge difference as well. I recently cleaned off 16 years of black oily gunk off of mine and what a difference it made!
Good tip!
Posted 25th Apr 2013 at 17:31
eskiiboi
Just ordered thanks Smile
Mine has just started to blip slightly when I press the clutch and revs ever so slightly on idle. Damn good price TBF. Already tried cleaning it but made no difference
Posted 25th Apr 2013 at 17:34
honestly3k
Well its been just about tolerable for that 40k as most of my driving is motorway.
So just been out for a quick 13mile blast and while it didn't stall when braking to a junction or dipping the clutch - didn't look like It wanted to either.
It does however, when I first start the engine, rev to about 2K rpm, then the needle drops to the low hundreds, like 300 or 400rpm, car shakes.....wants to stall but hasn't - this issue was present before.
So I will know more tomorrow after ive driven it around all day but im not convinced just yet it has solved my issue.
Ive got an almost brand new lambda sensor to go on too, but im thinking maybe it could be this PAS sensor ive read about too.
Time will tell....
Posted 25th Apr 2013 at 17:38
24seven
Did you disconnect the battery for a while at some point? Usually after changing an ICV an ECU reset clears any remaining troubles I've found. You don't have to leave it disconnected for too long, 10 minutes usually does it.
Posted 25th Apr 2013 at 17:46
honestly3k
Yes fella, disconnected the whole time I fitted the new one Dunno
Posted 25th Apr 2013 at 17:47
Pas sensor imo. Just disconnect it and you will know after the first start
Posted 25th Apr 2013 at 19:35
honestly3k
Ok just unplugged the PAS sensor, and this is how it behaved afterwards.
Please note the engine will be more or less cold at this point, generally my problems don't become apparent until shes hot.
This is me blipping the throttle then letting it idle, the rev counter rises very slightly after each blip and rest.
This is with the PAS sensor unplugged. I'm guna drive it around tomorrow with it unplugged.
Hope this link works
http://s956.photobucket.com/user/honestly3k_2009/media/VIDEO0003_zps0f19c698.mp4.html
Posted 25th Apr 2013 at 20:05
anth
Drive it high into the revs then put the clutch if that doesn't stall it ignore it Smile.
One thing I don't miss about these cars is the poxy idle.
Posted 25th Apr 2013 at 21:38
woody.
Yup my idle is the same as that. I've given up trying to sort it out. Spent too much money on sensors!
Posted 26th Apr 2013 at 13:36
honestly3k
So driven around all day with PAS sensor unplugged. And its idled perfectly!
Doesn't hunt when warm, and when switching the engine on when hot the revs don't fly up the counter then drop like a stone threatening to stall!
Strange, does that indicate anything?
With the PAS sensor plugged in it behaves a little unstably, but the new ICV has helped a hell of a lot I think
Posted 26th Apr 2013 at 15:22
Bascially it just means that when plugged in your PAS sensor is sending a load of BS to your ECU and your ECU is rasising the idle to try and compensate but its actually a load of bulls**t.
Replace it and plug it back in and it should be fine, Or if you leave it unplugge dit should be ok also, but its likely it will rev quit elow and struggle occasionally at full lock as it isnt compensating for the drain o on the engine from the PAS pump
thats how i understand it anyway
Posted 26th Apr 2013 at 15:43
Kale
I've had good experiences with ultrasonic cleaning ICVs. Just drop the whole thing in the fluid and leave it buzzing for a while. The shaft from the ICV can be pulled off (gently though) so the cleaning fluid gets to all the small places inside it.
A small ultrasonic cleaner with heating shouldn't cost anything more than £50. I've one and used it several times to clean little bits of the car. Like ICVs, injectors, throttle bodies (won't fit there all the way but then I just turn it around a few times) greasy bolts and nuts. Works like charm and renews parts that aren't working correctly because they are dirty.
Tho' I've come across a few ICVs that were worn and needed replacing because of it.
For injectors it's better to wire them up to a 9v battery or something alike, 9v is usually enough for them to open. Some injectors need 6v and other 12v. I have it wired up while they are in the fluid and use a switch to open and close them. If I want to make them good as new I buy a set of seals, filter baskets and pintle caps beforehand (for example Mr. Injector sells these on ebay) and change them. Old parts are better to be removed before the cleaning to get the best results Smile
306 S16 "Peugeot Sport GrpN" '94, 405 Mi16 "OEM+" '89, 605 SV24 "Executive Express" '91
Posted 28th Apr 2013 at 15:55
Had enough of my 6 stalling all the time even wound the throttle body open a little and it still does it. We have a trade account with euros with decent discount so I'll quote this part number to them and see what price they come up with. If their crap I'll do the same as you Wink.
Posted 19th May 2013 at 19:02
gwyn rallye
Managed to pick up a genuine brand new one of these on ebay last week.... £19.99 delivered! Bargain! Smile
Bianca white 306 Rallye
Arctic blue Clio 182 FF
Alpine white 205 1.9 GTI
Posted 20th May 2013 at 22:54
They now show a photo of the right one but list as by Intermotor
Posted 14th Apr 2019 at 22:20
pugsy77
Try this
I bought two just in case and they worked a treat!
306 RALLYE
Posted 13th Jun 2019 at 19:30
Good find
Posted 13th Jun 2019 at 23:19
mocinim
https://www.ebay.co.uk/itm/Leerlaufregelventil-Luftversorgung-Magneti-Marelli-230016079087/122633031335?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D0c3800e28c8942db875cab2724218fd1%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D122633031335%26itm%3D122633031335&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A8a59b214-8ecb-11e9-80ef-74dbd1800eb9%7Cparentrq%3A5713d5a616b0a9cb6bf029dfffdc3d65%7Ciid%3A1
Mine come from Germany cheeeeeeeeep works nicely
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 14th Jun 2019 at 18:43
pugsy77
That's the same one.
306 RALLYE
Posted 16th Jun 2019 at 14:39
