displaying posts 26 to 41 of 41
Pages (2): 1 [2]
Author Subject: Lightest 17 inch wheels
clen666
What about the wolfrace trackready range? Unsure on fitments but seem reasonably priced
Team 'unintentional rat look'
Posted 23rd Apr 2013 at 12:09
superchargedblack1997gti6
Thankyou yes they look intriguing only 8.1 kg in 17 inch
Not so sure on the looks still and they appear to just be multiplied drilled with holes so one fit end fits all. Thanks for the that Thumbs up
Posted 23rd Apr 2013 at 12:17
Ever thought the kad stuff just doesnt work because of what it is, not the size of the rotor.
Posted 23rd Apr 2013 at 13:01
You could be right. Lets hear you're recommendation Welshpug any other decent brakes other than the Ap's? the reason for the lightweight 17s is to try and lessen unsprung weight as i realise its importance.
Posted 23rd Apr 2013 at 14:25
24seven
Buy smaller wheels if you want to reduce unsprung weight, not bigger ones. Also just because there are 6 pistons in the callipers, doesn't make them better. If you're finding you need to go up to 17" to put larger rotors under the 6 pots my suggestion would be to see if you can sell them and put the money towards a 4 piston calliper that fits better and then maybe go up to a 16" wheel as well. Aside from the unsprung mass, 17" wheels will require a much lower profile tyre and that will cost you noticeably more traction.
Posted 24th Apr 2013 at 01:33
As i said 24seven only going to 17s for rotor size. And the thread for lightweight is trying to get some 17 inch wheels that aren't to much heavier than the 15s already have. Thumbs up
Posted 24th Apr 2013 at 13:08
beez_neez_gt
Its not about the weight of wheels its more the size that makes the difference.
Its the wheels and tyre forum not wanted forum lol.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 24th Apr 2013 at 13:22
It's the size not the weight? Really !! As for the wanted I'm trying to find information on the lightest 17 inch wheels!
Posted 24th Apr 2013 at 14:11
beez_neez_gt
Bigger wheels means higher centre of gravity, car goes higher up, you could lower car to suit but you can only go so far before the arms hits the bump stops or arches etc.
Pug fee`ver,
Posted 24th Apr 2013 at 14:53
Post #35
Guessing to keep everyone happy with 17s have to go dimma/wide arch the maxis ran 17s on Tarmac rally didn't they?
Posted 24th Apr 2013 at 15:04
beez_neez_gt
Post #36
My point is if you had 15's on with the same lowering amount it will give the car a lower centre of gravity thus better handling etc than with 17's.
At a guess the same goes with having a car really really low is much the same as having too bigger brakes imo. 4pot brakes are more than enough and this means you will have a much bigger choice of lightweight alloys to choose from which means you can be picky on the style you want as well without having to pay too much for them, bigger wheels tend to go for more money.
Pug fee`ver,
Posted 24th Apr 2013 at 15:22
Post #37
Agreed but surely I'd have more suspension travel with 17s?
Posted 24th Apr 2013 at 15:24
Post #38
It's all bo***cks if the rolling radius of the tyre is the same. 15's, 17's, 10's, 22" chrome spinners...
Posted 24th Apr 2013 at 15:36
Post #39
Thanks Phillip any recomndAtions on a lightweight 17 inch alloy?
Posted 24th Apr 2013 at 15:41
Post #40
No idea Big grin
However, I would ask what pads you're running in the calipers, you should be able to lock up with ease unless something is wrong or your caliper is designed for a much larger disc?
Posted 24th Apr 2013 at 16:20
Post #41
Ds2500
I thought the same but never worked great and I have overheated them many times, not on track ap racing 5.1 fluid too which has been changed and bled.
Posted 24th Apr 2013 at 16:37
Pages (2): 1 [2]
