Author Subject: Beam problem, Tyre's catching for some reason ?????
steve h gti-6
Hi
Ill try to keep a long story short if I can sorry.
As you may have seen ive just changed my beam over to another good one etc. The last beam was lowered and had been on for 8 years and neither back wheels or tyres caught anywhere in the arches even with 3 people in the back (17x7" 205/40/17).
Just had the new good beam lowered to the same drop as last time and now the passenger back tyre is scrubbing badly, it looks as though the passenger side wheel is closer to the inner lip than the drivers side.
I can get my fingers in between the drivers side tyre and arch but only just on the passenger side where its scrubbing. Its like the passenger side wheel/tyre is closer to the arch than the other side for some reason.
before I go call/go back to where I got it lowered has anybody got any suggestions to something im over looking ?????????
Many thanks in advance
"Gotta Love The 6"
According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL !
Posted 20th Apr 2013 at 20:01
simonjames
other beam had camber ?
what offset are the wheels ?
MY EBAY ITEMS
07943066306
Posted 20th Apr 2013 at 20:25
steve h gti-6
Wheels are correct offset as had them on my previous lowered beam for 8 years with no scrubbing. Back right dose not scrub but back left does now and only with this new beam after lowering which is much closer to the inner arch.
Can I adjust the camber ????
"Gotta Love The 6"
Posted 20th Apr 2013 at 20:32
simonjames
no camber is a sign of bearing collapsed if its closer inner arch have you now got camber on this beam ?
MY EBAY ITEMS
07943066306
Posted 20th Apr 2013 at 20:53
jord294
How do you know it was a good beam?
Posted 20th Apr 2013 at 20:54
steve h gti-6
I bought it from Colin at Pug Performance he said it was a good beam and then lowered for me.
he just said it was off an X plate and thought it was lowered and all good, took it home and fitted it, it wasnt lowered wasn't so went back again, he lowered it. scrubbed once on way home but didn't think much of it to be honest.
Out today with wife and kids and it just scrubs all the time especially when turning right over even slight bumps and even just at 30mph so not giving it any beans.
My last beam never ever scrubbed 3 up in the back over the 8 years I had that beam.
"Gotta Love The 6"
Posted 20th Apr 2013 at 21:05
its donald ducked Thumbs up
if Colin didn't take it apart and inspect the shafts he wont have a clue of its condition and essentially just robbed you.
Posted 20th Apr 2013 at 21:16
jord294
Unless you buy a beam newly rebuilt or one with a recent build history, then you can't always rely on what people tell you.
I've seen many beams which visually look in good order, but when stripped, are donald ducked
Posted 20th Apr 2013 at 22:01
steve h gti-6
Just spoke to Colin as he replied to an email. he said if the beam etc is bad and anything to do with him/his work he will rectify at no cost which is a good answer so fair play to him there.
he did suggest checking the gap if there is one where we put the shaft back in after lowering, if no gap undo the 6 beam bolts and try to persuade the beam over to the drivers side to get it dead in the middle, or get some peeps to sit in the boot to see exactly where it is catching and go from there. or gently pull back the arch a mm or 2 to bring it away from the tyre.
He did say it was in good condition as it all came apart very well and sweetly and went back together just as well with no problems, I was there so can back him up there.
It may be where he said as its in very good nick the top of the tyre is where it should be and not being lazy and cambering in towards the inner arch and now catching if that makes sense.
I do remember on my old beam it was closer passenger side than drivers side so it could be something as simple as the above its now sitting properly and catching whether I like it or not, unless I need to pul the arch out very slightly or try to move the beam across after loosening the 6 bolts off as suggested.
I think Colin is probably right as he does know his s**t when it comes to Pugs
"Gotta Love The 6"
Posted 20th Apr 2013 at 22:14
swiftyboi006
Ye colin does know his sruff but everyone is wrong at some point. The old beam must have had camber.
Black p3 Love
Posted 21st Apr 2013 at 07:34
aaron6
Dont pull the arches, and if he suggested it then id worry about the work he does... The beam should be fine and would never normally scrub. As it does, take it back and get it sorted. Failing that, force a refund and go find jord. Wink
Posted 21st Apr 2013 at 08:53
swiftyboi006
^pretty much this
Black p3 Love
Posted 21st Apr 2013 at 09:27
steve h gti-6
Managed to move it over about a mm and seems to have sorted itself but still need to test with a car load. Bounced up and down and no scrubbing so it may have settled into a normal position as the gap each side in the arches is more equal each side now.
Fingers crossed its ok now
"Gotta Love The 6"
Posted 22nd Apr 2013 at 20:36
aaron6
Keep us posted. Thumbs up
Posted 23rd Apr 2013 at 12:46
darkgti6
If its of an x reg and not been rebuilt it is long overdue. If its been dismantled to lower that will only compound the problem.
Team Peugeot Sport 308 Gti�
Posted 23rd Apr 2013 at 12:52
miles
The best way to check without taking it apart, is the beam seal where the trailing arm goes into the beam, Must be a uniform gap around it all, this is where the bearing issues will show as if it has this you will have less of a gap at the top, the arm should just touch the seal, any more and it can wear it away.
If this is OK then the beam's good, but each beam you get will show different camber to a degree on them as thats the way the things are
www.pugracing.com
Posted 23rd Apr 2013 at 22:00
beez_neez_gt
What i check is how high above the arm is in relation to the edge of the beam where seal is. It should be level with the beam, too higher up than the beam then the bearings have most likely collapsed.
So whats the best way to make sure beam is centralised, please dont say drive on flat straight road for a while then do nuts up once beam has centralised lol.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 23rd Apr 2013 at 22:08
steve h gti-6
So far so good good no more scrubbing, had a close look with no gaps anywhere, and to my eye the beam looks central with a uniform profile around the seals where they meet up.
Fingers crossed when i can do a loaded up test it should prove ok.
"Gotta Love The 6"
Posted 24th Apr 2013 at 08:05
