displaying posts 1 to 25 of 46
Author Subject: XU10J4RS block with XU10J4 (S16) HELP!!!!!!!!!!!!!!!!!!!!!!!!
Takedown
I let PP Motorsport make up some forged turbo pistons for my car and some forged conrods (1000+BHP rated) with ARP bolts.
And ive made the biggest error ever, theyre for the RFS engine, the XU10J4RS engine , and not for my XU10J4 S16 engine
what are my options?
fitting a RFS lump isnt an option since almost everything from my turbokit is made to match the S16
Will a S16 head fit a RFS underblock?
Posted 19th Apr 2013 at 22:14
birk
Put new flanges on your manifolds.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 19th Apr 2013 at 22:17
block and crank is the same, afaik the valve centrelines are the same, so will work ok as long as valve reliefs are large enough as the diameters vary between the two.
S16 is NOT the J4R, its just J4.
Posted 19th Apr 2013 at 22:24
Takedown
Welsh, the RFS conrods are 10mm longer then the S16 one...
ive been told my kit wont fit the S16 engine...
Got more info?
Posted 19th Apr 2013 at 22:33
How did you manage to make that mistake ?
Could always try and sell them and start again ?
Posted 19th Apr 2013 at 22:34
JWP EFi
Turbo Legend!
Got more info?
only 6mm longer mate
Posted 19th Apr 2013 at 22:38
Takedown
Oke then 6mm i didnt measure...
But can i use them or not?
cause i dont know s**t about the difference between these engines, and i feel gutted!
Posted 19th Apr 2013 at 22:40
yes, but piston crown is shorter obviously...
Posted 19th Apr 2013 at 22:42
Takedown
So theres nothing to worry about ?
Posted 19th Apr 2013 at 22:46
XU10 Deck height is all 235mm.
RFS conrod (158mm) and piston in RFS block, RFS crank (same crank and block as RFY)
RFY piston and rod (152mm) in the same block.
Posted 19th Apr 2013 at 22:48
swiftyboi006
Welsh is the man, i dont think hes ever been wrong. I think he once saw a pig fly
Black p3 Love
Posted 19th Apr 2013 at 22:59
Takedown
Oke , big relief!!!!!!!
Welsh i pmed you with a question
Posted 19th Apr 2013 at 23:07
JWP EFi
Turbo Legend!
you'll be lucky to get a reply
Takedown
Uhmm whys that?
Posted 19th Apr 2013 at 23:12
Replied Razz
Pistons are shorter in rfs.
Longer rods will give lower side thrust forces and
Posted 19th Apr 2013 at 23:23
Takedown
Im a Lucky guy Wink
thankyou Welsh
Posted 19th Apr 2013 at 23:25
So you could run a diesel crank as well if you machine off 1mm off the piston ? Then you have steel crank and 2.1 Dunno
Posted 19th Apr 2013 at 23:30
No, 2044cc, not quite 2.1, tharts 87x88, 2088 cc.
Posted 20th Apr 2013 at 01:54
birk
Still classed as a 2.1 though.
07889376885
Dan
Posted 20th Apr 2013 at 10:08
naah, gotta be over 2050 to be a 2.1.
Posted 20th Apr 2013 at 10:26
birk
Yea, thought he said it was 2088cc
07889376885
Dan
Posted 20th Apr 2013 at 10:39
Takedown
Welsh you know what compratio these 8.5:1 RFS pistons in the RFY engine will give with a standard thicknes HG??
thx in advance
Posted 21st Apr 2013 at 11:34
you need to figure out what the dish "should" be to give 8.5-1 on the RFS, then compare the differences and work from there.
Std gasket thickness - RFS - 1.20mm.
Gasket bore - 87mm.
1998cc / 4 = 499.5cc (per cylinder)
Total clearance volume:
499.5cc / (8.5-1 compression ratio) = 58.77cc.
Gasket volume : 87x87x3.14159x1.2mm = 7.13
RFS chamber Vol - 37cc.
therefore dish should be circa 14.64cc.
so: RFS dish + RFS gasket + RFY head
14.64cc + 7.13cc + 40cc = 61.77.
499.5 / 61.77 = 8.08-1.
I believe that's all correct, sounds about right to LOL
You do need to confirm how much lift @ TDC you can run.
I did roughly measure the valve centres and they are the same between RFY and RFS at 40mm, also centreline distance from the side of the combustion chamber to the face of the valve measured in at the same 25mm, valve sizes are very close also, so if the piston designers have given you enough clearance on the radius of the valve cutout you'll be fine.
Posted 21st Apr 2013 at 12:08
Takedown
Welsh you the man,
What means this though ?
And heres a stock S16 piston vs the Forged one
Posted 21st Apr 2013 at 13:12
that is not an S16 piston, its an 8 valve piston LOL
Posted 21st Apr 2013 at 13:36
