I've been thinking of changing the angle of the steering arms. Not through choice really, and at the moment its still slightly hypothetical..
Ignore I mount ny steering arms to the hub, but fitted on top of the hub mounting, obviously the angle would be pointing upwards when the car is on the floor stationary...
This is where the issue with potential bump steer becomes able issue.. By starting them at an angle, is that going to make it worse? As in the standard position, there isn't any real problem... Or would there not be as much if a problem as im thinking?
I know a bump steer gauge is the answer, but this is early plannibg stages.
devere
