Having trouble removing the valve stem oil seals from the head. Just wondered if there was any specific technique or tool to be used?
| Author | Subject: Valve Stem Oil Seals |
brucerussell1
Newbie Location: Buxton Registered: 19 Oct 2009 Posts: 2 Status: Offline |
Alright guys,Having trouble removing the valve stem oil seals from the head. Just wondered if there was any specific technique or tool to be used? Cheers |
stan_306gti6
Obviously you won't be using them again, so you can use some pliers, these should do the trick. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
brucerussell1
Yeah fair enough. We're just a little worried about crushing the valve guides. Have tried doing this but wouldnt like to grip much harder. |
bas_306gti
Regular Location: Eindhoven Registered: 06 Sep 2012 Posts: 108 Status: Offline |
you won't crush the valve guide that easy, Be careful not to scratch the bores the lifters fit into |
Valve stem removal and installation kit £14 on eBayhttp://bit.ly/10RKqqo ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
306xsi
Junior User Location: Suffolk Registered: 08 Feb 2006 Posts: 90 Status: Offline |
Bit of a thread revival....Is it necessary to use a tool for placing new stem seals or can they just be pushed on by hand? It doesn't look like they're held in place by anything, is that the case? |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
306xsi wrote: Bit of a thread revival.... Is it necessary to use a tool for placing new stem seals or can they just be pushed on by hand? It doesn't look like they're held in place by anything, is that the case? Use 10mm long socket and a small mallet to drift the seal into place! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
306xsi
That's great thanks alot. |
