Author Subject: Paddle
JWP EFi
Turbo Legend!
Running a paddle clutch plate with a OE Valeo/LUK pressure plate - is this a good thing to do, ie in terms of reliability?
This seems to be a popular mix n match with the Turbo diesel owners. I can't think of any reason why you would to do this other than to retain 'some' clutch feel and travel.
Posted 3rd Apr 2013 at 21:04
Would make the pedal lighter,but you are lowering the clamping force of the clutch so abit pointless using a paddle plate I would thinkDunno
Cause the clutch would still be on/off taking up movement.
Posted 3rd Apr 2013 at 22:18
I have a Helix paddle plate and a Sachs cover if this is of any interest?
Seems to work well in my car.
Posted 3rd Apr 2013 at 22:57
Paddle clutches don't like to slip, at all. Not enough clutch surface to dissipate the heat.
Posted 4th Apr 2013 at 09:24
jonnie205
Its a good idea. Peugeot 206 cup and fiesta st rally cars run a std pressure plate and uprated disk. It actually clamps the paddles harder as there is less area plus the advantage or having an unspung disk adds strength. Plus the springs increase transmission losses. Stiffer pressure plates are a pain as they can increase stress on the cable and clutch mechanism as well as the pedal box and are only realy needed with very high power outputs
Posted 4th Apr 2013 at 16:46
clen666
Hmm so you wouldn't recommend a sprung plate to dampen it a bit?
Jim, is that why some people say the 6 paddle clutch is more manageable on the road than a 3 or 4, as it has greater heat dissipation?
Team 'unintentional rat look'
Posted 4th Apr 2013 at 22:32
That and they're not usually as harsh on engagement because the plates tend to be offset slightly in a 3 + 3 setup.
Posted 4th Apr 2013 at 22:37
clen666
Phil, would you also advise on using a fixed plate over sprung?
If there's not much difference I'd rather go fixed for the weight saving
Posted 4th Apr 2013 at 22:46
If you're going for silly torque figures, yes, or hard rally launches.
If it's staying relatively sane and for road/track use, I'd go sprung as it does reduce the shock loadings through the driveline.
Posted 4th Apr 2013 at 22:55
clen666
Thumbs up cheers, sprung it is
Posted 4th Apr 2013 at 23:00
