Author Subject: Thermo/Cooling fans
BradlehGordz
Hi guys!
This issue has had me confused for a while, I have replaced and the brown sensor and bitron/cooling fan relay and the thermo fans come on when the brown sensor is unplugs, but not at the certain temperature. Dunno
Would I be right to assume there is a broken/corroded pin and the connector behind the front bumper where it screws/connects to the thermo fan housing?
- Brad
Proud owner of a gti6 '98
Posted 1st Apr 2013 at 07:09
- Brad
More than likely, yes. Yes
Posted 1st Apr 2013 at 10:23
BradlehGordz
I had a look at it today when I took the bumper off and I was wondering the best way to disconnect the plug, it unscrews from the engine bay side, yeah?
I tried from the top and there is very little hand room and couldn't get it. So I decided to clean the bumper while it's off.
Anyway, whats the recommended plan of attack to unplug it? Smile
Posted 7th Apr 2013 at 08:53
Grippy gloves or I usually pop a thin screwdriver in one of the slots and give it a tap. There's a tab where it's clipped in a slot. Giving that a slight pry I find can help.
  • Posted 7th Apr 2013 at 09:41
    BradlehGordz
    Tip with the screw driver worked wonders! Wink
    There was a pin that had a fair bit of oxidation, so I cleaned both connectors with contact cleaner, and I cannot tell that they had been oxidised. Hopefully that was the culprit and I shall try in the morning! Thumbs up
    Posted 7th Apr 2013 at 11:52
    Sounds like you've made some headway at least, good luck for when you try it out. Thumbs up
    Posted 7th Apr 2013 at 19:58
    BradlehGordz
    The car hit 100 and no fans came on, manually engaged them via a switch to cool the car down and turn it off. Sad
    What could be the culprit otherwise? Dunno
    Posted 8th Apr 2013 at 08:50
