Author Subject: Lightened flywheel dowel problem Kindve an emergency request
phil b
The dowel hole ain't lining up whilst tryna fit it, anyone else had this problem and how you to round it??
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 31st Mar 2013 at 17:30
Nope not had this problem No
Posted 31st Mar 2013 at 17:38
beez_neez_gt
By how much, a little or a lot ?
Maybe use some brake cleaner after a quick sand using emery paper.
Edit, do you mean all the crank holes line up but dowl still doesnt?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 31st Mar 2013 at 17:43
Onto crank, or clutch onto flywheel?
Posted 31st Mar 2013 at 18:00
phil b
The crank dowel doesn't line up on te lightened flywheel, when attempting to tap it on (wood and Irish screwdriver) it is catching the inside of the dowel and burring it,
If you look at the two side by side its ever so slightly noticible,
When I get back to the car ill get my measurements off the vernier
Bearing in mind this was bought second hand and 'fitted to previous engines' with pics I'm a bit baffled
I've a couple of ideas in my head but anyone else got any b4 I mention them??
Kinda p'd off too as I wanted to get the lump in today so I could start building the bodies and bay back up Thumbs down
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 31st Mar 2013 at 22:17
tvrfan007
Is your dowel damaged? Perhaps peened over or distorted?
Got another you can try off say, another engine?
Alternatively removing the dowel, offering the flywheel up and establishing with a drill bit or whatever that the two holes align. If they do you could try gently inserting the dowel.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 1st Apr 2013 at 08:23
jeffers Forum Admin
Moved to more appropriate section! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 1st Apr 2013 at 08:44
phil b
Soz Jeffers was abit distraught and p**sed off y'day
No it's not the dowel, it fits std flywheel not a problem!!
And bollox if I'm swappin the crank!!!
I either send the flywheel to an engineering place to have the hole elongated and poss rebalanced, or a take my ickle grinder and shave a wee bit've flesh off the top of the dowel to slide it on but keep the dowel??? Opinions please Cry Cry
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 1st Apr 2013 at 09:23
As above, remove the dowel, bolt flywheel up and check if the holes line upThumbs up
If they do your dowel is damaged, either replace or get it machined downYes
Posted 1st Apr 2013 at 14:41
Never had this problem, although I do remember the lightened flywheels being a fairly tight fit on the crank dowels, but nothing a small tap didn't sort out.
Posted 1st Apr 2013 at 14:51
Same hereThumbs up
Posted 1st Apr 2013 at 15:06
phil b
Fairly tights like saying the popes a little catholic in faith......
Might skim a bit off the dowel with the mini grinder, I got a dowel on my old lump if I give up and I go std flywheel...... (Which won't happen FYI ) as I'm not up fr modifying the flywheel and messing up balancing
The little tap did nowt either
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 1st Apr 2013 at 17:24
In that case then you definitely have an issue somewhere. Yes
I have fitted a few of these in my time now and it's never taken more than 2 minutes per time to get the flywheel fitted on that dowel. Smile
Posted 1st Apr 2013 at 17:28
tvrfan007
Something isn't right here. My flywheel was second hand and I got it straight on my engine no problem. It was a little snug on the dowel but it went on without bother, I didn't even need to tap mine home.
I think you should remove the dowel as I said before, then fit the flywheel bolts loosely, and try to slot a drill bit or similar through both. Your dowe l must surely be damaged, especially given your flywheel has come off an engine.
For clarity, I am ssuming you're using a Rich_W flywheel? Or are you fitting some sort of standard one that's been machined?
I'm Si btw Tee hee
Posted 1st Apr 2013 at 18:10
phil b
Yeah rich w jobby
Jobs sorted now, through a stroke of bad luck grips made a hash job of tryna remove it so gave it a little shave, should stop the bugger comin out n all
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 1st Apr 2013 at 20:25
Glad you've resolved the issue, but really can't think what the problem was in the first place. No
Posted 1st Apr 2013 at 23:07
phil b
Slight difference In tolerances both ways I think stan, I wanted to try n resolve without resorting to butchery and if anyone had similar experience but in the end bit've bad luck resolved original bad luck LOL
Now I'm tryna squint at loom wires for the omex loom swap (ph2 to ph1)
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 2nd Apr 2013 at 02:02
