I have a problem with the running of the car. It has a miss fire at idle, but seems to run ok under acceleration. Now all things would seem to point to the coil packs, I have tried with a spare one I have here, but I can't pinpoint which one is the problem, or the one which I think seems to be causing the problem does not change when I put the other coil pack in.
Now, what I could really do with is someone who would be willing to 'test' their coil packs on my car, so I can confirm or not, a coil pack being the problem, before I shell out on new coil packs. I am not 100% that is the cause, hence the ask.
I could get to wherever you are, do a quick switcheroo, see if it runs properly on known working coil packs, then swap them back.
That is the easiest trouble shoot I can think of, I would welcome any suggestions. I've tried the removing individual coil packs, 3 seem to cause an instant laboured idle on 3 cyls, whilst when I remove the one nearest the battery, there is a slight delay before the engine labours on 3 cyls. I would think that cylinder is the cause, but is does the same thing on the spare (unknown good or bad) coil pack I have, which is why I would like to try swapping all 4 with known working ones, before buying new ones.
I have no idea what it would be if not the coil pack(s).
Would anyone be willing to assist in troubleshooting? Thanks in advance!
'00 Astor Grey GTi-6Team: 'EVO Triangle'
This is a quantum car. I don't know where I am, but I'm going really fast.
PS3 ID: Skaankypuppy
Normally play GT6
