displaying posts 1 to 25 of 34
Author Subject: Superchip ecu reset
hsustyle
Silly question about it I'd rather be safe than sorry..
New Rallye has a Superchip fitted, Receipts for about, £240 including power run and printout. Bla bla
I'm looking to fit a standard exhaust rather than the Powerflow and the standard airbox.
Then reset ecu.
Will an ecu reset it affect the chip at all? I gather it's a generic map and not an actual remap.
Beef Beyond Belief
Posted 26th Mar 2013 at 10:05
can't see it affecting it but tbh i would be more intent on removing it personally
Posted 26th Mar 2013 at 10:06
hsustyle
Yup I can't see why someone would spend that money on a generic chip.
It's currently on 173bhp with K&n, sports cat, Powerflow and this Superchip. I was expecting a bit more..
Just wanted to make sure the chip doesn't throw a paddy.
Beef Beyond Belief
Posted 26th Mar 2013 at 10:11
The chip has a generic 'map' stored on it, resetting the ECU won't lose this so don't worry.
However as Rikky says, you're probably best off removing it. Thumbs up
Posted 26th Mar 2013 at 10:24
scott.t16
Mine had the same set-up as yours when I first got it - superchip, powerflow exhaust and k & n fitted.
I've put a standard exhaust and airbox back on since, but kept the superchips ECU mainly because I can't be bothered to go through the hassle of removing it.
I've reset the ecu at least once and haven't had any problems. Hope that helps Amin
Ph3 Black Gti 6
Posted 26th Mar 2013 at 12:33
hsustyle
Ok cool, thanks for that Scott. Three black 306s in Crowborough now!
Beef Beyond Belief
Posted 26th Mar 2013 at 12:42
scott.t16
Yeah I know... Good to hear you're back in a 306!
Got any plans for it?
Ph3 Black Gti 6
Posted 26th Mar 2013 at 13:07
hsustyle
Nothing major, just standard exhaust and airbox, refurb cyclones in silver, repair ripped drivers seat and new Rallye decals.
It's pretty damn tidy overall. I'll get a progress blog up soon.
Beef Beyond Belief
Posted 26th Mar 2013 at 13:54
Why remove the superchip...
I thought these were actually pretty decent?
Good gain in the mid range?
Posted 26th Mar 2013 at 15:19
hsustyle
Graph looks smooth and torque is steady too.
Beef Beyond Belief
Posted 26th Mar 2013 at 15:59
Because they are a generic map. The only real benefit any change to the mapping will be if the map is bespoke for your particular vehicle, then it's worth doing. Yes
Posted 26th Mar 2013 at 16:26
scott.t16
Any idea how you would go about getting these removed Stan?
I've always thought Superchips would probably charge you to get the original map reinstalled, so haven't really bothered.
Ph3 Black Gti 6
Posted 26th Mar 2013 at 16:40
Better than the standard one though surely? As thats only generic as well?
Posted 26th Mar 2013 at 16:45
smegal
As us the low boost supercharger map.
Ex SC-6
Now in a Megane R26
Posted 26th Mar 2013 at 16:49
Exactly the same problems occur with the low booat generic map from what I can tell. Yes
Some cars stall more than others and some have hesitation in the mid-range, all of which could be ironed out or bettered with a bespoke map.
Posted 26th Mar 2013 at 22:29
Leave the superchip inThumbs up
Yeah its not as good as custom re-map but it won't hurt changing exhaust/air filter etc.
They are a old style chip in these, that needs phsyically removing and a standard chip refitting, so quite an expensive job imo for something that does not need doing!Thumbs up
Posted 27th Mar 2013 at 09:01
This is very true, it won't hurt it as such being there and it will cost to get it removed. I personally would rather not have it but for the cost of removing it, might not be worth it.
Posted 27th Mar 2013 at 09:35
If you really do want rid of it sell your ecu and transponder/chip etcWink
And say buyer must part ex there standard ecu and transponder/chipThumbs up
If you do decide to do this drop me a pm please, as I would be interested in yoursYes
Posted 27th Mar 2013 at 13:51
hsustyle
Will do. Cheers for the info.
Beef Beyond Belief
Posted 27th Mar 2013 at 14:04
mattgti6phase2
A super chip map is installed via the diagnostic port so can very easily be converted back at very little cost.
The difference is nothing. Slight advances to ignition is the only difference. When mine was standard it made standard power with a very healthy graph no dips at any point in the rev range for power or torque so IMO its not worth touching.
Cams and or bodies would be the only time i would bother with a remap (custom) small adjustments like decat exhaust and air filter the ECU can learn itself and adjust accordingly.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 27th Mar 2013 at 20:28
Are you sure?Dunno
Cause I know Andy bought a ECU off RichW with a Superchip in it and the chip came loose so Rich had the ECU back to re-fit it.
Also if you can re-map via the diagnostic port why do Chip Wizards have to solder in a port so they can adjust the map?Yes
Posted 27th Mar 2013 at 20:34
smegal
Are you sure?Dunno
Correct. On new cars, this may be the case, but on older cars you have to change the chip.
Ex SC-6
Now in a Megane R26
Posted 27th Mar 2013 at 20:50
mattgti6phase2
100000000000000000000% a 306 can have its map altered via diagnostic. The ECU has an EEPROM style chip so it can be re written and put back to standard. They remove the standard file and save it on the laptop then put the new file on.
5 x a 306 owner!
Posted 28th Mar 2013 at 09:56
Strange that is, as I've been told by demon tweeks, who are superchips dealers, that the ecu needs opening up and a new chip insertingYes
Also spoke to motorsport developments in blackpool that produce the evolution chips and they said the sameDunno
So you have actually seen it done via diagnostic port?
Posted 28th Mar 2013 at 11:19
Also why do chip wizards go to the trouble of adding a cable with a connector into the ecu to alter the map if it can be done via diagnostic port?
Posted 28th Mar 2013 at 11:22
