quality lovely sounding and great fitting system to suit above manifold 4 branch to fit 205 gti with mi16 (2.0). £250 ono will fit gti6 with mods or the full system£400
2.0 mi 16 big valve and ported head £200 to clear.
2.0 mi 16/S16 std head low miles ( sub 5k) £250 ( less cams)
2.0 mi 16 S16 catcam inlet cam less than 3k use ( £150) or will do with head £300)
2.0 Mi 16/S16 bottom end. in very very good condition. less than 5k £400
will do the S16 Mi16 bottom end and head complete for £600 ono ( engine has head removed for inspection).
mocal 13 row oil kits x2 and pipes hardly used 1 nearly new with oil filter housings £110 ea.
set of red mi16 205 samco water hoses £85 as new.
set of 205 8v 1.9 gti samco blue hoses £85 in very good order
std 1.9 8v 205/309 gti machined head, aligned and pressure tested and rebuilt with new stem seals... £150
rebuilt 8v full engine 205 gti 1600 £100.
205 /309 turbo technics 5th injector control box x2 £50 ea. turbo technics wiring loom £100
205 / 309 TT ecu £50
205 / 309 TT AFM £50
205 / 309 TT distributor rare specially adapted by turbo technics £75
MF2 5th injector 2d and 3d mappable cost £425 new looking for offers on £200 with loom and 5th injector.
omex 600 loom connector mated to loom from a turbo charged rover 620ti, can be adapted to make pug loom. £50
also Standard 1,9 gti fuel pump adapted to feed carbed engines great working order, basically used in conjunction with a forward after market fuel pump but pumps the fuel out of the tank offers on £60
309gti (fits 205) rear beam complete, 1000 road miles since full rebuild 5 years ago, been in storage off the car 3 years with 206 gti rear calipers pads and discs...
As I am putting in a std s16 lump into my recently aquired 205 gti I am also selling a the 2.1 (s16 mi16 iron block)engine in pieces so spec as below:
Cast iron 2.0 block bored to 86.5mm
New 86.5mm pistons and rings done 1k.... 250
88mm crank (standard is 86mm) 150
This gives a displacement of 2088cc
All new mains thrust and big end shells were replaced.
The correct bore MLS head gasket.
whole bottom end £500
Head: UNFITTED AND STILL UNASSEMBLED FOR INSPECTION.
Full skim and pressure test
1mm larger valves
Properly ported head £200
"Fast road" Cams £175
piper verniers £80
head £350 in pieces
whole engine £600 as a package.
Pending mot check I may be pulling the miami blue 205 to pieces but it owuld be a shame.
if it flies through its mot which it should heres the spec.
s16 engine with vts box
Drive train:
Brand new SACHS clutch
vts 5 speed box
Brand new 1.9 Gti Drive shafts
Suspension:Bilstein sport shocks all round
-30mm springs
309 Gti rear axle with discs
1.9 gti hubs
powerflow exhaust
4 branch manifold.
12 months mot
no tax.
Auto bonnet
smoothed tailgate.
tidy grey leather interior, on log book as a 1.6.
£1995.
306 less for first time in nearly 7 years. Lets keep it that way... please refuse any offers i make to buy your 306 ( doctors letter supplied by request)Marmite and cheese sandwiches anyone???
x box "yippeekayaymofo"
yippeekayay
