Author Subject: wont idle.
fordygti
After changing the tappets my engine ran.much quieter. But after a while it became.noisy again and won't.seem.to idle.
When you build the revs up and let off it won't stop at idle it just goes down and cuts out.
Any ideas on what this could be?
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 24th Mar 2013 at 20:43
Icv maybe ? Bad timing ?
Posted 24th Mar 2013 at 20:46
meoldchina
Idle control valve / stepper motor
Mine does this occ, esp when very cold
Other threads about idle mention map, tps & lamba
How many times has it happened?
meoldchina
Posted 24th Mar 2013 at 20:48
fordygti
I does it every time it has been started. Makes it impossible to drive.
Ice has been cleaned. I've had my mates diagnostics on it and there are no fault codes. Surly if it was a sensor it would show?
Posted 24th Mar 2013 at 20:53
306xsi
Changed the stepper on mine recently which has solved the problem for me so far. When i was looking for solutions the power steering sensor was mentioned as a possible cause also if I remember.
Posted 24th Mar 2013 at 20:56
fordygti
Just seemed odd it only happened since the tappers were changed. It's never happened before.
Posted 24th Mar 2013 at 20:57
fordygti
My first impression saysits the idle control valve because starts.and idles but when u add revs and when it goes down it didn't stop at idle.
But surely it would have brought up a fault code.
Posted 25th Mar 2013 at 19:20
jammamayhew Banned!
My old 6 did this.... was the power steering sensor
My new 6 did this.... was the power steering sensor
JAMMA "M44YHW" MAYHEW
LOSE WEIGHT NOW - ASK ME HOW -
NUTRI-FIX
GTi6 LPG, The best of both worlds!
2006: 1997 R reg 306 1.4 Miami - Diablo Red - DEAD
2007: 1999 V reg 306 1.4 Meridian - Diablo Red - SOLD
2007-09: 1998 S reg 306 GTi6 - Diablo Red - DEAD
2009-10: 1998 R reg Corsa 1.2 - Blue - SOLD
2010-13: 2001 Y reg 306 GTi6 LPG - Diablo Red - DEAD
2013 - 2013: 2000 X reg GTi6 LPG - Moonstone Blue - DEAD
2013 - current: 2001 X reg GTi6 LPG - Diablo Red
]FOR SALE[/b]
"I LIVE FOR THE 306"
Posted 25th Mar 2013 at 19:21
fordygti
Silly question then. How's does that effect the engine idle.
Posted 25th Mar 2013 at 19:34
it causes the engine to rev when used so I can see it causing an issue.
Posted 25th Mar 2013 at 19:53
fordygti
True
Posted 25th Mar 2013 at 19:57
PAS sensor has contributed to loads of idle issues on these cars. Yes
Simply unplug it and see what happens. Thumbs up
Posted 25th Mar 2013 at 22:54
fordygti
Were is it situated?
Posted 26th Mar 2013 at 10:33
Blue sensor on the power steering pipe if i member right
Posted 26th Mar 2013 at 16:05
fordygti
Yh I.got it. No difference. I also have. Coolant leak.aswell. and there is a lot of thick cream in the oil cap. I've got a feeling its the hg.
Not.good on a rebuilt engine less than 500miles old. Sad
Posted 26th Mar 2013 at 19:07
swiftyboi006
Who rebuilt it?
Black p3 Love
Posted 26th Mar 2013 at 21:39
Thick cream in the oil cap?
Definitely sounds like the HG on if's way out. Try this:
Run the car up to temp and then switch it off. The next morning go outside, pop the bonnet and remove the rad cap. There should be zero sound. If you hear a 'hiss' or there is loads of pressure there then the HG is almost certainly going/gone. Yes
Posted 26th Mar 2013 at 22:36
fordygti
Thanks Stan.
Posted 27th Mar 2013 at 05:32
fordygti
its not head gasket. Had a sniffer test done and its all fine.
The cream in the cap i asumme then is due to condensation front sitting there for so long being started and stopped over the winter.
The dodgy idle is still there, ive unplugged all the sensors and the only one which dosnt affect it is the ivc, would that indicate that is the problem?
Posted 29th Mar 2013 at 10:22
woody.
Yup sounds like it. I had a sh*t idle and did the whole cleaning thing but it just came back a couple weeks later. Best of replacing it.
Posted 29th Mar 2013 at 10:32
fordygti
I cleaned it and it made no differnce. Ill try another.
Posted 29th Mar 2013 at 10:38
Did you perform the test I stated as well as getting a sniff test done?
Posted 29th Mar 2013 at 11:04
fordygti
I did, but there has always been a hiss since i fitted the nissans rad and used the old cap, just assumed it was an old worn cap....
Posted 29th Mar 2013 at 11:10
