Its for a 98 Phase 2 so the IR one please, I dont care about the casing of any of that i just want one that works and holds the charge on the batteries thanks!
| Author | Subject: Key fob |
higgsy
Regular Location: Portsmouth Registered: 24 Jun 2006 Posts: 101 Status: Offline |
I've bought about 2/3 off ebay,every one i've bought the batteries just run out after about a week..if that! So im after a key fob that will last longer than a week please Its for a 98 Phase 2 so the IR one please, I dont care about the casing of any of that i just want one that works and holds the charge on the batteries thanks! |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Any keyfob wont just work with any car.________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
higgsy
I don't understand why you would say that? |
E.L. Jimmy
Newbie Location: Ireland Registered: 11 Nov 2012 Posts: 36 Status: Offline |
1. replace the battery?????2. do you not need to code the fob to work on YOUR car. If not, does any 306 fob open any 306 car???? 3. even with new batteries the IR has only about a 1 meter range at best. |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
I got one if you need one________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
You need two keys to reset the fob btw________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
I can't remember the specific fault, but on the P2 fob there is a short that appears in the circuit which will cause the battery to drain itself after about a week. However it is possible to reprogram fobs to work with your car, search the FAQ for the appropriate guide on how to do this. ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
smithers
Seasoned Pro Location: Glasgow Registered: 22 Nov 2004 Posts: 1,016 Status: Offline |
hovis16 wrote: You need two keys to reset the fob btw Just need the blade in the ignition which you can separate from the fob to program it to the car Had the same problem with the battery discharging, went through loads of 2nd hand until i got a working one. ________________________________________ 1997 Black GTi6smithers205 at hotmail.com |
