Author Subject: Help!! Wont start
aled5188
HI got a 306 gti 6 and it wont start, im not a clued up person under the bonnet so hoping some one could help me,
she turns over she doesn't fire, it doesn't seem to be injecting fuel as the spark plugs are dry.
could some one give me advice on wot to do or wot could be wrong??
Posted 17th Mar 2013 at 16:21
bas_306gti
can you hear the fuel pump upon startup ?
Posted 17th Mar 2013 at 16:43
JWP EFi
Turbo Legend!
start with all the basic things, is there fuel in the tank? does the pump prime when you turn the ignition on?
Posted 17th Mar 2013 at 18:53
chris1987
I had the the same problem a couple of months a go after checking all the sensors i found out the connecter for the cut of switch was loose so pop it bk on fould out i had to push the button and it started first time hope this helps .
Posted 17th Mar 2013 at 19:24
dendle89
Is this a black 6 ?
Team 6 Cylinders
Posted 17th Mar 2013 at 19:29
chris1987
Yea Smile
Posted 17th Mar 2013 at 19:33
dendle89
No i ment it to aled lol
Team 6 Cylinders
Posted 17th Mar 2013 at 19:38
chris1987
Lol no problem Whistle
Posted 17th Mar 2013 at 19:41
Yep, as above when you switch the ignition onto the second click do you hear the fuel pump prime? Dunno
Posted 17th Mar 2013 at 19:42
rich306
As already said, please check if the cut of switch is activated?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 17th Mar 2013 at 22:22
aaron6
Do you have a spark?
Posted 18th Mar 2013 at 07:04
It sounds more of a fuel issue at the moment rather than a spark. Wink
Posted 18th Mar 2013 at 07:30
Dual fuel relay at the back of the battery box?
Posted 18th Mar 2013 at 09:47
I'm thinking along the lines of fuel cut-off switch activated/not plugged in correctly, multi-function relay died, or bad connection at the inner wing loom plug. Yes
This is all providing the issue is fuel and the OP can't hear the fuel pump priming.
Posted 18th Mar 2013 at 09:50
