Author Subject: removing front 1/2 carpet from a 306 rallye
rhyds247
i'm stripping my 306 rallye shell in the hope of turning itno a stage car.
ithe carpet needs to come out to go into my road rally car & i'm stuck
there is 1 bolt left underneath the centre console which i cant seen to get out
anyone have any tips or pictures ? it would be ideal
diolch
V187 ROC - GTI6 Road Car
R81 TBC - GTI6 Road Rally / Stage Rally Car
T893 BDN - Rallye Shell & Long Term Project
T260 TDL - Knackerd engine but handy for parts
Y42 JAJ - Black HDI Company Run Around
Posted 11th Mar 2013 at 18:48
Which area do you think the fixing is left in?
It's pretty obvious when you start removing things around the area and move it and see where the resistance is. Is it the handbrake section you're having trouble with or the under dash bit where the ash tray is?
A pic of where you've got to and where the struggle is may help.
But if in doubt and you get fed up - pull it hard until something breaks and put a wanted add up LOL
  • Posted 11th Mar 2013 at 18:52
    rhyds247
    its the section underneath where the hazard switches are, in front of the gearstsick. just 1 bolt left from what i can see. shell is surrently outside & its dark so will post a pic up tomorrow
    Posted 11th Mar 2013 at 18:55
    If you can see it - undo it or remove/force what you need to out of the way to do so.
    I've never had a problem removing one so fail to see/remember any access problems.
    Have you removed the screws at the back side of it?
  • Posted 11th Mar 2013 at 18:58
    Here's a picture of someone who recently had the problem.
    This could be you very shortly.
  • Posted 11th Mar 2013 at 19:00
    rhyds247
    will give brute force a bash in the morning to see what happens. thanks for the help
    Posted 11th Mar 2013 at 19:01
    Takedown
    just rip it out, i did the same....
    Posted 11th Mar 2013 at 19:53
    How are you getting on? Please advise.
  • Posted 12th Mar 2013 at 12:48
