Author Subject: stuck 12mm bolt
monkeyman
Ive got a stuck 12mm bolt I'm trying to free. An impact driver and socket has just rounded the bolt, I thought I was using a face grip socket, but it pushes itself away from the bolt as it turns, even with heavy leaning.
Ive cut a groove in it to use as a screwdriver head, but again no luck with impact driver.
any ideas or experience with these
Stud extractor not sure if there is enough room around the bolt head to use this.
another stud extractor not sure if this will grip a rounded bolt
bolt remover probably what I'll get unless there's any bad reviews
cheers
Forum Search Clicky
Posted 9th Mar 2013 at 11:46
What is it holding on?Dunno
The only downside with snapped bolt removal tools is if they snap in the bolt you are right in the s**t thenYes
Can a nut be welded on the end of bolt?This works well as the heat from the weld travels down the bolt and helps release itWink
Or can the head of bolt be ground off with a angle grinder?
Then remove the item its holding and you can access the remaining part of the bolt left inYes
Posted 9th Mar 2013 at 11:52
dendle89
Hammer on a smaller socket ?
Team 6 Cylinders
Or try hammering on a Torx socketWink
Posted 9th Mar 2013 at 11:54
monkeyman
The bolt is pretty soft so I may have to hammer a small socket on it, it joins an ali subframe to a steel mainframe with not much room around it so I dont think it will grind off without me cutting through some frame : (
I dont have any welding stuff but I think the bolt is aluminium
Have just found this which looks good Irwin bolt remover set
Forum Search Clicky
Posted 9th Mar 2013 at 12:24
I've got a tool that will get that off if you're in Southampton anytime soon?
Don't hammer on a socket, that's a good way to f**k up the bolt even more and break a socket.
Posted 9th Mar 2013 at 12:30
dendle89
Yea hammer on a smaller socket, failing that try a torque socket then
Team 6 Cylinders
Posted 9th Mar 2013 at 12:31
The first 2 stud extractors you linked to will not work, they are for studs not bolts. The last one might but I'd be dubious as to wether or not the skinny shafts would snap before the siezed bolt came undone (avoid).
Posted 9th Mar 2013 at 12:38
monkeyman
Never seen a months wages look so tempting Love
I'll probably go for the Irwin set off Amazon, unless my local tool shop has something this afternoon, thanks for the advice,
Forum Search Clicky
Posted 9th Mar 2013 at 12:52
dendle89
Has never failed me at all, just dont be too harsh with the hammering and u'l be fine but that tool set would be handy
Team 6 Cylinders
Posted 9th Mar 2013 at 12:54
Those Irwin's are worth their weight in good when in your position.
The sort of thing you resist buying for Justin Case, but when you need one you wish you had a set to dust off.
  • Posted 9th Mar 2013 at 13:22
    I only buy stuff like that when it's on offer, I think they were £80 but it's only got to save me reaching down the side of an engine block to weld a nut to a rounded bolt once and as far as I'm concerned it's paid for itself. Had it a year and only used it once so far, but yeah handy thing to have up your sleeve. It's the reverse thread thats the clever bit, the harder you lean on it the more it srews itself onto the bolt head, so you can consentrate your effort on turning without having to cope with trying to keep it pushed on as well, I was impressed anyway.
    Posted 9th Mar 2013 at 15:03
    monkeyman
    Bolt was no match for......
    Dad's big Stilson
    There was a big C-R-E-A-K as it came loose, which I thought was it shearing. Lots of copper grease before it goes back on Thumbs up
    Forum Search Clicky
    Posted 10th Mar 2013 at 19:58
    When you say "goes back on" I take it you are going to replace the bolt? Dunno
    Posted 10th Mar 2013 at 20:01
    monkeyman
    Good point, it doesn't look bad now its out, but I will replace it with a stainless one
    Forum Search Clicky
    Posted 10th Mar 2013 at 20:13
    I was wondering, having rounded it off how exactly you were planning to refit it. LOL
    Posted 10th Mar 2013 at 20:20
